Old September 10th, 2013, 10:57   #16
abctdi
abctdi's Avatar
Often times higher boost leads to higher EGT, but if the turbo is bigger this may not be the case. Knowing both and their limits is a good idea for longevity.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old September 10th, 2013, 11:54   #17
JFettig
JFettig's Avatar
I'm curious why he downgraded your turbine wheel from one that is rated at 170hp to one that is rated at 150hp.
The stock BV43A pumps out 26psi happily with EGTs in check.
High boost does not equal high EGT. Pushing the capabilities of the turbo does. There is a Compound B4 wagon on here running 50psi and he has a hard time breaking 1000F EGT.
Do you have any more pictures of this turbo?
Jon
JFettig is online now   Reply With Quote
Old September 10th, 2013, 19:50   #18
CharlieT
On the BHWs, they have an EGT probe as stock.
Group 67 in VCDS, in Deg C.
My RC1+ ran to 876 Deg C under WOT, which is 1600 Deg F.
2012 NMS TDI SEL, 39k
CharlieT is offline   Reply With Quote
Old September 11th, 2013, 07:03   #19
50harleyrider
I should do a WOT log ASAP to see how high they are. Does anyone have any data on the limit the BHW pistons can take and for how long?
50harleyrider is offline   Reply With Quote
Old September 11th, 2013, 07:07   #20
JFettig
JFettig's Avatar
pistons won't be the limiting factor, your turbine will melt before the pistons do.
Your turbine is rated at 1650F, the BV43A turbine is rated at 2000F
Old September 11th, 2013, 07:20   #21
50harleyrider
Jon
NO more photos. I'm sure Frans would furnish some if you asked him. The turbine side is fat and beefy too compared to the VA. I assume you mention the 150 hp fom the vb turbine wheel? I got the mildest hybrid he offered because of stock injectors and slushbox. I'd love to get this car on a chassis dyno. I'm sure with the stage 2 tune it's easily pushing out 180hp. Also no more whining, just normal sweet sounding turbo boost (whooswh and scream at WOT)!
Old September 11th, 2013, 07:23   #22
50harleyrider
So as long as my EGT is <1650F, no worries for pistons or turbo?
Old September 11th, 2013, 08:24   #23
JFettig
JFettig's Avatar
As long as you have a good tune and your injectors aren't streaming - yup!
Old September 11th, 2013, 10:46   #24
50harleyrider
Injectors streaming? You guys are killing me with acronyms. I assume streaming means too much fuel from bad injectors,tune or what? This would translate to high EGT?
Old September 11th, 2013, 11:14   #25
JFettig
JFettig's Avatar
streaming isn't an acronym, its what you do when you go to the bathroom, lol
You'll be fine, drive more worry less.
Old September 11th, 2013, 12:15   #26
Frans
TDI(s): Golf MK2 TDI
Richard, you have the "standard" bv43a, which I modified for optimum durability and reliability. Will be good for approx 200 hp.
I also have (garrett) hybrids for these passats, up to 240-250hp.
Frans is offline   Reply With Quote
Old September 11th, 2013, 13:19   #27
50harleyrider
Thanks Frans,
Your turbo is awesome
Old September 11th, 2013, 15:44   #28
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Is there a way to tap into the probe wiring to install an EGT gauge?
-George Bernard Shaw
Old September 11th, 2013, 15:48   #29
JFettig
JFettig's Avatar
absolutely do not tap into that wire, do not cut or splice. -ETA- thermocouple wires - look it up
You'll have to install a separate probe.
Old September 11th, 2013, 20:36   #30
1854sailor
Resident Curmudgeon
1854sailor's Avatar
That's exactly what I was thinking. Is there an "easy" spot to insert a probe?
How To: R/R B5.5 BHW Alternator Pulley MOGolf VW B5 Passat TDIs 52 May 16th, 2017 01:16
2005 Passat B5.5 (BHW) TDI part out Fireblade16 Private TDI Items for Sale/Wanted 6 September 27th, 2013 23:44
FS: 2005 Passat TDI BHW B5 Oil Pan speedeagle Private TDI Items for Sale/Wanted 0 June 15th, 2011 19:23
B5 BHW engine in Europe? got4g63 VW B5 Passat TDIs 6 March 26th, 2010 10:57
B5 Passat BHW engine problems blaz Ontario 10 February 15th, 2009 15:33
Page generated in 0.16524 seconds with 11 queries
[Output: 129.74 Kb. compressed to 108.30 Kb. by saving 21.44 Kb. (16.52%)]
