Old March 22nd, 2002, 21:21   #31
danix
danix's Avatar
Default Re: Traction Control(ASR) Need a Ginnie pig
Glad to see the site back.
I can now confirm the following: ASR/EDL can be retrofitted to our cars simply by swapping the hydro unit and computer from a car that has this feature. My 99.5 Jetta is happily NOT chirping its tires in 1st and 2nd gears.
What I have not figured out yet is the wiring - the unit is powered up already, all I need is the defeat, if I want it.
This mod makes a world of difference - remember my threads about the car having no traction? That problem is nicely remedied now, at least at lower speeds with EDL.
I would say that after the Upsolute chip, this mod was the most bang for the buck and the one I would do over all others besides the chip.
Eric (SVTWEB) has now also done this on a 2002 car, and has figured out the wiring.
danix is offline   Reply With Quote
Old March 22nd, 2002, 21:57   #32
Michael Moore
Danix:
Thanks for all the great work on this project. I am really looking forward to doing it myself (sounds like less of a headache than PDC <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" /> )
Here are a series of wiring diagrams that deal with various combinations of ABS. They are from the European service information, so be alert for possible differences with your North American car.
Wiring Diagram 07 - Anti-locking brake system (ABS), Anti-locking brake system (ABS) with electronic differential lock (EDL).pdf
Wiring Diagram 12a - Anti-locking brake system (ABS), Anti-locking brake system (ABS) with electronic differential lock (EDL), and traction control system (TCS).pdf
Wiring Diagram 46 - Anti-lock brake system (ABS) with electronic differential lock (EDL), traction control system (TCS).pdf
Wiring Diagram 58 - Anti-locking brake system (ABS), Anti-locking brake system (ABS) with electronic differential lock.pdf
Michael
Michael Moore is offline   Reply With Quote
Old March 24th, 2002, 18:56   #33
tongsli
Michael,
The PDF you posted doesn't show an ASR switch [img]images/icons/frown.gif[/img]
L
tongsli is offline   Reply With Quote
Old March 24th, 2002, 19:46   #34
tongsli
Michael,
For your consideration...
Old March 24th, 2002, 19:52   #35
Michael Moore
Tongsli:
I don't have the knowledge to comment with confidence on the diagram. I will go to my Canadian dealer tomorrow and get the correct wiring diagram that shows the switch.
Michael
Old March 25th, 2002, 05:01   #36
danix
danix's Avatar
I'm pretty clear on the diagram - I still don't quite get how it works, as there is some momentary switching going on, but all I need to do is find the wires I need to tap. Again, Eric (svtweb) has this done.
I will soon have another hydro unit on the way for the next candidate...
Old March 25th, 2002, 06:19   #37
Michael Moore
Lito, Danix:
Try this diagram, it has a switch shown on sheet 5. Hope this is the correct one.
12a - Anti-locking brake system (ABS), Anti-locking brake system (ABS) with electronic differential lock (EDL), and traction control system (TCS).pdf (68 kb)
Old March 25th, 2002, 17:06   #38
oldpoopie
oldpoopie's Avatar
so does this wind up being a poor mans quaife?
Old March 25th, 2002, 20:34   #39
tongsli
Michael,
that's the right diagram.
L
Old March 25th, 2002, 22:18   #40
danix
danix's Avatar
Put it to you this way -I thought the car sucked in the snow even with dedicated snows. Today with Zrated summer tires I was able to get home at brisk speeds without any trouble in some rain/snow mix. Like I said, it's right up there with Upsolute as a must have.
Old March 26th, 2002, 08:54   #41
eluwak
<font size="2" face="Verdana, Helvetica, sans-serif">What is the total cost/parts list for this project if I were to buy this new? What would be the difficulty rating from 1 (raplace valve stem cover) to 10 (installing quaife)? Down here in the rain I have very little traction and have to start off very slow to avoid sitting there and spinning my wheels so I am interested in this mod.
Thanks in advance
eluwak is offline   Reply With Quote
Old March 26th, 2002, 16:13   #42
MOGolf
MOGolf's Avatar
Originally posted by SVTWEB:
The Hydri unit is the only difference between the cars With ASR and the cars without.
The ASR/EDL hydro Unit's have an extra pair of solinoid valves to give it the capabilities of ASR.
The problem that I have is 2002 Vehicles use te Mk. 60 ABS/EDL/ASR unit, the 2001 and earlier use the Mk. 20......
<font size="2" face="Verdana, Helvetica, sans-serif">I was reviewing this thread and have to pick a nit here. The change from Mark 20 unit to Mark 60 occurred during the 2001 model year. Early 2001's had Mark 20. Later 2001 have Mark 60. My Golf built 12/00 has a Mark 60. VAG-COM reports it as such.
The Bentley (hardcopy page 45-9) indicates the Mark 60 is only ABS or ABS/ASR (no indication of EDL). However, the new CD version states there are 4 different controllers.
1C0 907 379 C / J ABS
1C0 907 379 D / K ABS/EDL/ASR
1C0 907 379 E / G ABS/EDL/ASR/ESP
1C0 907 379 F / H ABS/EDL/ASR/ESP 4MOTION
Bentley (hardcopy) reports 2001 Jetta's got the Mark 60 from vehicle #9M-1-094323. No number provided for Golf/GTI.
And I didn't notice mention of using VAG-COM or equivalent to code the control module according to the tables in the Bentley.
[ March 26, 2002, 16:18: Message edited by: MOGolf ]
MOGolf is offline   Reply With Quote
Old March 26th, 2002, 18:51   #43
SVTWEB
The date was a misquote on my part.. They started using the Mk60's in 2001MY.....
As for the rest of the post.... I'm not sure what kind of answer your looking for?
[ March 26, 2002, 18:52: Message edited by: SVTWEB ]
SVTWEB is offline   Reply With Quote
Old March 27th, 2002, 05:21   #44
oldpoopie
oldpoopie's Avatar
so how much $ for the upgrade?
Old March 27th, 2002, 20:16   #45
danix
danix's Avatar
Cost - used controller/hydro unit, $100-500 depending where you buy it.
1 liter brake fluid, $10.
Having traction at last, priceless.
Difficulty - not very. If you can carefully use a wrench and know how to bleed/flush your brake fluid, it's about a 3 on a scale of 1-10, about the same as doing a brake job, but less labor.
I combined mine with a complete brake job.
In broad strokes:
- jack up car, remove 4 wheels
- (optional) R/R brakes all around
- remove airbox, MAF
- crack FL brake line to release pressure
- carefully remove brake lines (6) at hydro unit
- release 2 hydro unit mounting bolts
- install new unit, attach lines
- drain old brake fluid
- install new brake fluid
- pressure bleed entire brake system
No reprogamming of anything or rewiring was needed. To gain a defeat switch some wiring will need to be done, but I don't see the need unless you are racing or something.
Page generated in 0.17103 seconds with 10 queries
[Output: 124.11 Kb. compressed to 103.89 Kb. by saving 20.22 Kb. (16.29%)]
