Old October 17th, 2011, 09:37   #1
Jeev
Default 2012 Golf TDI: Winter Tire Size Help
My 2012 Golf TDI Highline comes with 17 inch tires (225/45/17).
I called a few VW dealerships and they say the smallest winter tire I can put on there is: 205/55/16.
I then called a few local tire places and they say that 15 inch winter tires (195/65/15) will fit.
Does anyone here know if 15 inch tires will work?
I know the 15 inch tires are better for going through snow, but is there any reason why i should go with the 16 inch tires over the 15?
I'm not sure if the factory lowered sport suspension on the 2012 Golf TDI makes a difference for tire options when compared to 2011 and 2010 MK6 models.
Thanks!
Jeev is offline   Reply With Quote
Old October 17th, 2011, 09:42   #2
dieseldorf
top post dawg
dieseldorf's Avatar
I think that you need to determine if a 15" wheel will fit on your car and whether you can source them.
General rule in snow is taller/skinnier (assuming you are within load rating and speed rating guidelines).
Welcome aboard, Jeeve!!
Old October 17th, 2011, 12:19   #3
sgoldste01
Just use the tire configuration tool that Tire Rack provides. It will tell you if 15" wheels are an option. If the 2012 Golf is like my 2010, then you'll find that 15" wheels will work.
SOLD: 2010 Golf 4-door TDI with 30k on odometer.
BOUGHT: 2012 Subaru Impreza Sport Premium 5-door with manual tranny.
sgoldste01 is offline   Reply With Quote
Old October 17th, 2011, 12:21   #4
740GLE
a search will show 15" rims can fit over the rotors on the mk6 Golf TDI. So unless you have upgraded rotors, then you'll be fine with 15" and save the cash as well.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old October 17th, 2011, 12:22   #5
djtj
I don't know 100 percent, but I've been told that 15 inch rims won't fit over the brakes
djtj is offline   Reply With Quote
Old October 17th, 2011, 12:34   #6
crashtested
crashtested's Avatar
15" and larger for the Golf, 16" and larger for the Golf Wagens.
'14 GSW
crashtested is offline   Reply With Quote
Old October 17th, 2011, 12:50   #7
IceRaider360
IceRaider360's Avatar
Fuel Economy: 4.7 L/100km
I just put mine back on today 195/65 R15 on my 2011 Golf TDI
IceRaider360 is offline   Reply With Quote
Old October 17th, 2011, 13:04   #8
wutbürger
wutbürger's Avatar
Go see what size your spare tire is under your hatch- that will seal the deal for you
Or, to save you time, it's a 15. And as stated, 15's on non-GTI Golfs will fit, 16's and larger on the JSW since they use the same rotor size as the GTI
Give a man a beer and he'll waste an hour, teach him to brew beer and he'll waste a lifetime
wutbürger is offline   Reply With Quote
Old October 17th, 2011, 13:15   #9
veedubfreak
TDI(s): 2011 golf
The spare is 15". The question becomes, is it cheaper to buy rims and tires in 15" or just buy tires for the stock rims.
veedubfreak is offline   Reply With Quote
Old October 17th, 2011, 13:18   #10
WVU TDI
WVU TDI's Avatar
Guys, lets keep in mind the original poster is in Canada, when a JSW is a Golf and the JSW requires 16" wheels.
If this is a regular old Golf, not a Golf Wagen, then yes, 15"s will fit.
1997 Passat TDI (sold)
2001 Golf TDI (sold)
2010 4dr Golf TDI, 6M (sold)
2013 Passat TDI SE, 6M (sold) -- turbo failed at 9500 miles.
2015 Passat TDI SEL DSG (current)
WVU TDI is offline   Reply With Quote
Old October 18th, 2011, 03:49   #11
740GLE
i think the jetta sportwagen ie golf wagen, has bigger rotors, so you'll def need 16".
i don't think this was clearly stated in other posts and other countless threads, i just wanted to clear that up.
Old October 18th, 2011, 05:24   #12
20IndigoBlue02
20IndigoBlue02's Avatar
Go to the dealership.
Head to the parts department.
Give them the VIN number
Ask for what size front brake rotor.
288mm = 15"
312mm = 16"
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old October 18th, 2011, 12:51   #13
eloreno
Did you buy the rims from tirerack? They're saying their 15" rims won't fit..
VW and me go back a-ways:
89 Jetta GLI: Drove this car for a long time.
02 Golf GTI VR6: It had all the options. Great car. FAST.
08 Rabbit 2.5: No problems to speak of.
2012 Golf TDI in UGM: Current ride.
eloreno is offline   Reply With Quote
Old October 18th, 2011, 13:08   #14
20IndigoBlue02
TireRack is right about 99.99% of the time. There is that .01% where they do not have all the information correct or available to them.
Old October 18th, 2011, 13:10   #15
15" wheels will fit on a Golf. Including the post above, there's a guy in Chicago who had pictures of his Golf with snows on it. Golfs have 288mm rotors. Jetta Sportwagens have 312s.
Tire Rack doesn't always stock or show fitment on all possible tire sizes for each car. More than once I've had them call me and tell me what I ordered won't fit my car. They were wrong.
2002 Jetta wagon, 407K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 14K. Principal, http://www.idparts.com
Winter tire size? jbrill VW B5 Passat TDIs 10 October 13th, 2006 17:23
Winter tire size aneblanc TDI 101 15 December 14th, 2005 20:18
tall/skinny winter tire size for 96 passat wagon Joa VW MKIII-A3/B4 TDIs 6 December 7th, 2005 06:33
winter tire size. cRaZyRaVr TDI 101 2 December 23rd, 2003 19:16
winter tire size terrman TDI 101 7 October 30th, 2002 00:43
Page generated in 0.17408 seconds with 11 queries
[Output: 125.08 Kb. compressed to 103.91 Kb. by saving 21.17 Kb. (16.92%)]
