Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > TDI Cars for Sale/Wanted
TDI Cars for Sale/Wanted VW TDI/Diesel cars for sale and wanted.
Old February 13th, 2011, 09:40   #1
DarrenB
Default 2003 VW Golf TDI - Lansing Michigan - 180,000 miles - $5,000 obo
I'll add some photos once I get a chance. I'm asking $5,000 obo. This is negotiable.
***PHOTOS HERE***
This is a 2003 VW Golf GLS TDI with 180,000 miles. 5-speed manual tranny. Options and add-ons are:
  • GLS trim stuff - Moonroof, power windows, locks, heated seats, etc. (NO stability control)
  • Thule Rack w/bike carriers, and fairing (will have to separate the kayak carrier...my girlfriend was really mad that I listed the car with those!)
  • Aftermarket coolant heater (for cold weather)
  • Complete set of snows and all-weather tires (NO extra rims though); snows are on the car now
  • CAT 2 fuel filter add-on
  • After market trailer hitch (hidden hitch)
  • 100k mile timing belt (done at 98,6**)
  • VW front-end bra (only top currently installed)
  • Old-skool Vag-Com. Works with serial port. I'll give you a serial-to-USB adapter
  • Bilstein TC suspension in Fall 2008.
***Lots of concern about the timing belt, so more info to clear up any misconceptions***Timing belt was done at 98,6** miles. The timing belt was replaced with a 100k mile timing belt kit from Dieselgeek. It is due for replacement again at 198,6** miles. You can drive the car about 18,6** miles without worrying about it again.
Glow plugs aren't really working - fault errors for several years. Haven't fixed because it doesn't really bother/affect me - the car starts and runs great as long as it's 20+ degrees F and/or I plug it in for half an hour before starting. It needs to sit overnight in temps less than 20 before it has trouble starting.
Currently, my driver's side window needs to be fixed. I'm just waiting to do it once the weather warms up. One of the Thule rack cross bars needs to be replaced because of rust - although it works fine and holds a load fine - just kinda looks crummy.
***ADDED DETAIL FORGOT ON FIRST RENDITION*** One of the rims has a slow leak. It's been like this, I crap you not, since I bought the car at 22,000 miles in 2004. VW wouldn't touch it under warranty (how do you prove slow leak?), so I've been stuck with the leaky wheel. It's NOT a tire issue, it's a wheel/rim issue. Basically, it requires air about every 10-14 days, depending on the weather. Kinda a pain in the rear-end, but it is what it is. Also, I left my remote key on a hot stove once, and melted the buttons together...needless to say, no more unlocking the car remotely (although the key still does work in the slot). Also, the trunk hatch pistons need replacing - the hatch will not stay open on its own. Also, one of the battery cable connectors is kinda jacked - every once in awhile the cable gets loose and the car won't start until you get out and jiggle it around a bit. I should be clear that the glow plug fault code causes the check-engine light to be on. I'm not kidding you, the CEL has been on since August of 2005. I don't worry about it because every time I've run the Vag-Com, it tells me the only faults are the glow plugs. I haven't had any problems with reliability at all. The weirdest problem this car has ever had is when the MAF sensor went on it in 2006 (I think). Even then, the car still ran...just not well. I ordered up a MAF and installed it in 10 mins. Good to go since.
I've run a lot of biodiesel (B20) through this car, and it runs great. I try to do a diesel purge once a year or so. I've always used high quality oil - either Amsoil or Delvac or Rotella. I actually have several gallons of oil that I'll give you with the car.
This car is extraordinarily reliable. Frankly, I can't believe how good it's been to me. I hate to get rid of it, but I just don't drive long distances anymore, and I want to buy a truck.
The price is negotiable, although I'm not going to give it away. This is a good car. tcmsuguy@gmail.com is my email address. The car is in Lansing Michigan.
2003 Golf GLS TDI, Reflex Silver; Turbo badge on the hatch, mudflaps, CAT 2 micron fuel filter set-up, ventectomy, TDI heater
DarrenB is offline   Reply With Quote
Old February 13th, 2011, 10:57   #2
LovintheTDI
Would you be willin to trade for a truck?
LovintheTDI is offline   Reply With Quote
Old February 13th, 2011, 11:31   #3
tymilu
E-mail sent.
tymilu is offline   Reply With Quote
Old February 13th, 2011, 16:39   #4
DarrenB
Not unless you've got a Chevy Silverado or a GMC Sierra 4x4 extended cab 2009 or newer.
Old February 13th, 2011, 16:53   #5
DarrenB
I just added some detail to my original post that I had forgetten concerning a slow leak on one of the wheels.
Old February 13th, 2011, 18:08   #6
r90sKirk
r90sKirk's Avatar
Q's
1) What oil has been run?
2) Who did the TB work at 100k?
Thanks,
Kirk
Honest TDI Enthusiast Performing Competent TDI Work
Currently Owning: 2006 Jetta TDI Laser Blue 269k, 2015 GSW (6MT) Pure White 78k, 1977 BMW R100RS 166k Silver Ice,
Gone, but not forgotten: 2013 Passat TDI SE 151k Opera Red, 2002 Jetta TDI Cool White 248k, 2000 Golf TDI 461k Bright Green, 1997 Jetta TDI Green 290k, 1996 Passat B4V Indian Red Pearl 337k
r90sKirk is offline   Reply With Quote
Old February 13th, 2011, 19:27   #7
DarrenB
See above: Amsoil, Delvac, Rotella Synthetic.
A TDI enthusiast/mechanic in Fowlerville.
Old February 13th, 2011, 19:55   #8
Growler
Got Soot Vendor
Growler's Avatar
what transmission is in it?
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old February 14th, 2011, 08:02   #9
DarrenB
Sorry. Manual transmission.
Old February 14th, 2011, 17:31   #10
DarrenB
Hi all - here are some quickie photos...I have NOT had a chance to detail or even wash this car - was too busy buying a truck today. A lot of people have been expressing interest and asking for photos so here are a few. I will really try and get the car cleaned up and take some more photos later this week.
LANSING, MI 2003 TDI GOLF PHOTOS HERE (CLICK)
Old February 15th, 2011, 05:51   #11
DarrenB
All - I added some timing belt details above. There seems to be much concern that the timing belt is/was due at 80k mile intervals. That is not correct (on this car). This is a 2003 with the 100k mile timing belt interval. It was replaced at 98,6** with another 100k mile belt. (see above for detail).
Old February 15th, 2011, 07:13   #12
Airgetcha
TDI(s): Red 01 GLS
Default drivers side door
in your pics, is the drivers side door left open?..what happened to the windshield?
Airgetcha is offline   Reply With Quote
Old February 15th, 2011, 16:17   #13
DarrenB
Not sure what you are referring to with the windshield - it's fine as far as I know. The door was just left ajar when I took the photo - my bad. The driver's side door is fine. The driver's side window is in need of repair - I stupidly tried to open it on a cold day, and the motor coughed ans sputtered, and next thing I know the window is in the door. So it's being held up by duct tape. Needs repair. Glass is not broken.
Old February 15th, 2011, 16:30   #14
DarrenB
Added some details about the car. As I was cleaning it up, taking photos, I remembered some other stuff. I added it above in blue.
Old February 17th, 2011, 18:54   #15
tomiegunn77
Is the window switch broken too? Just curious as to the tape across it..
tomiegunn77 is offline   Reply With Quote
2002 VW Jetta TDI GLS Sedan, $8500 obo, Lansing, Michigan NanoMonkey TDI Cars for Sale/Wanted 13 September 2nd, 2010 06:03
FS: 2003 TDI Golf 2 Door 53,000 miles Robert'sVW TDI Cars for Sale/Wanted 3 April 23rd, 2010 15:46
Will my 2003 Jetta TDI make it to 1,000,000 miles? tonystdi TDI 101 35 December 19th, 2009 13:10
2000 VW TDI Beetle in DE with 215,000 miles $2999 OBO mdtdiguy TDI Cars for Sale/Wanted 2 October 12th, 2009 10:40
FS 2003 Golf GL TDI auto 16,000 miles - Minnesota belfert TDI Cars for Sale/Wanted 0 October 1st, 2004 06:19
Page generated in 0.19382 seconds with 11 queries
[Output: 127.08 Kb. compressed to 105.97 Kb. by saving 21.10 Kb. (16.61%)]
