Old February 11th, 2011, 15:35   #1
jdhunt0
jdhunt0's Avatar
TDI(s): 2005.5 Jetta
Default Alternator Pulley Removal Tips
Due to the suggestions from this site I decided to replace my alternator pulley to try and fix the problem of my tensioner bouncing ant the occasional squeal at startup. I ordered the pulley and also got the toll from metalnerd.
My problem is coming from the removal part. The center bolt is in there TIGHT. It is right hand thread isn't it? Am I going to have to pull the alternator and use an impact wrench?
jdhunt0 is offline   Reply With Quote
Old February 11th, 2011, 15:53   #2
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Although it may appear to be left-hand thread, it isn't... the pulley unscrews from the alternator shaft normally - although it might be corroded in place... (the belt moves the pulley in the tightening direction which adds to the hold they have on each other...)
MetalNerd does not recommend the use of impact tools for this, but some people have found it necessary on occasion...
Yuri
Pereat mundus, fiat musica!
ymz is offline   Reply With Quote
Old February 11th, 2011, 15:58   #3
jdhunt0
jdhunt0's Avatar
I'll try again tomorrow. Thanks.
Old February 11th, 2011, 16:06   #4
migbro
TDI(s): 2003 Golf GL
I had the same problem when I did mine. Thought I was going to break something. So I took a cotton ball, soaked it in Kroil and stuffed it into the recess in the center of the pulley. After about an hour I put the wrench to the pulley again and it came off easily.
This thread
is helpful when thinking about which wrench to turn and in what direction.
2003 Golf GL TDI 5-speed 131,000 miles
migbro is offline   Reply With Quote
Old February 11th, 2011, 16:10   #5
jdhunt0
jdhunt0's Avatar
This thread
THANK YOU!!!
I was holding the pulley and turning the shaft.
Old February 11th, 2011, 16:17   #6
ymz
That's why some people think it's left-hand thread when it isn't... You can hold the pulley and turn the shaft, but then you need to be aware of what direction you're turning...
Have fun... (?????)
Yuri
Old February 11th, 2011, 17:15   #7
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Be careful - those metalnerd tools are strong
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old February 13th, 2011, 07:08   #8
jdhunt0
jdhunt0's Avatar
I got the pulley changed this morning. No change to the tensioner bouncing up and down.
Maybe I have avoided a future problem, but right now I feel like that was $90 well wasted. What next? How much "bounce" is normal?
Old February 13th, 2011, 08:33   #9
Henrick
I checked my serp. belt tensioner while the engine was running/idle this morning. The tensioner was bouncing like it was shown in some video flying around here. Do I also have a failing alt. pulley? Should I start worrying or just wait untill it fails?
BTW, my alternator is Valeo (not Bosch) 140 amp. Any ideas if the pulleys are replaceable/available for these?
Henrick is offline   Reply With Quote
Old February 13th, 2011, 15:27   #10
apples12
I had my alternator pulley replaced whilst my golf was in the garage and whilst the chaps had the belt off i had them replace the alternator belt, this managed to completely fix the bouncing tensioner after the chap adjusted it accordingly and now the car runs sweeeet!
replace the pulley, replace the belt with it, adjust tension accordingly and take it from there
if the noise is still there, time to consider the condition of the alternator...
apples12 is offline   Reply With Quote
Old February 13th, 2011, 17:52   #11
jdhunt0
jdhunt0's Avatar
I was not aware there was an adjustment.
Old February 13th, 2011, 18:30   #12
jdhunt0
jdhunt0's Avatar
Ordered a belt.
Old June 15th, 2011, 09:23   #13
Henrick
Today I've replaced the belt, pulley and serviced the alternator (rings, brushes). After all this was done and new belt installed the tensioner is still bouncing slightly.
Oh, and don't buy that overpriced POS Metalnerd tool! It's very high chance you'll need it only once. Pulley replacement without any other alternator service at a specialized shop is less than $10 so much cheaper plus no dirty hands. During that time you can smoke a cigarette or two.
Old March 25th, 2018, 18:21   #14
easyfix
Thumbs up alternator replacement video
Complete alternator replacement is another way to go that can be faster and easier in the long run. That is what I typically do as a mechanic. Here is a video to help out too if you need it! ~shaun
https://youtu.be/-tTTL_VX018
easyfix is offline   Reply With Quote
Old March 25th, 2018, 19:31   #15
ToxicDoc
TDI(s): 2001 Jetta
You spamming all the alternator threads you can find?
ToxicDoc is offline   Reply With Quote
Alternator Pulley removal tool? Sickly West Coast Canada/USA 8 June 13th, 2009 14:03
Tool Part number for Alternator Pulley Removal and removal help? JimO VW B5 Passat TDIs 2 September 12th, 2007 18:07
Looking for alternator pulley removal tool bryantdi2 Ontario 6 November 1st, 2006 19:55
Alternator clutch pulley removal / install tool. Anyone have one? Ironforger TDI 101 2 January 25th, 2006 16:11
Alternator pulley removal skizziks TDI 101 3 November 21st, 2005 19:43
Page generated in 0.15553 seconds with 11 queries
[Output: 125.15 Kb. compressed to 103.97 Kb. by saving 21.18 Kb. (16.92%)]
