Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Passat TDI Picture Gallery
Passat TDI Picture Gallery Do you have a Passat TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old April 11th, 2012, 19:34   #331
JFettig
JFettig's Avatar
So in the pic above with all the oil, where else could that be coming from other than the intake?
I think I'm just too much of a surge junkie for the BV43. Could have been FOD, could have been surge.
Just need to fix the exhaust and button up.
I got curious to see what the VL would look like on there. Bolts and ports won't line up, especially without a spacer.
JFettig is offline   Reply With Quote
Old April 12th, 2012, 19:48   #332
JFettig
JFettig's Avatar
Back alive!
Sadly, back alive with only 17.5psi.
The whole reason I popped the hood in the first place was to disconnect the downpipe to redo the connections to the muffler then to the rest of the exhaust. I didn't take the time to cut and weld new connectors onto the muffler, instead it got replaced with an 18" long 2.5" tube. Wow that thing is throaty sounding and in the car, it is not much louder. Outside, completely different story.
Old April 16th, 2012, 21:00   #333
tail090382
tail090382's Avatar
TDI(s): vw b5 afn
hello JFettiq, whats the volvo turbo partnumber?
tail090382 is offline   Reply With Quote
Old April 17th, 2012, 19:44   #334
JFettig
JFettig's Avatar
Its from a Volvo D5.
30757079 might be the part number It also says 757779-4 on it.
Old April 18th, 2012, 20:47   #335
NoJoke
The VL is a great choice for drivability! Will you connect coolant to it? Also what will be your HP for the Porsche; unless you bought another VL?
97 B4v ALHcompoundT's GLX AWD conversion
06 E320 CDI - RC
NoJoke is offline   Reply With Quote
Old April 19th, 2012, 04:08   #336
JFettig
JFettig's Avatar
I have a GTB2056VK that I'll stick on the Porsche. It solves my actuator problems, I can tuck it right next to the block and use a tubular manifold.
I don't plan on connecting coolant lines at the moment, but if I decide to, i can use the EGR coolant lines.
Old April 19th, 2012, 07:03   #337
NoJoke
That worked out nicely on both ends. Keep up the good work!
06 E320 CDI - RC
Old April 21st, 2012, 19:00   #338
JFettig
JFettig's Avatar
Teaser pic, more tomorrow if I finish
Old April 21st, 2012, 19:07   #339
JFettig
JFettig's Avatar
Oh, and this
The cash is for the bodies I'm picking up on Tuesday.
Old April 25th, 2012, 12:19   #340
sirpuddingfoot
sirpuddingfoot's Avatar
Pins and needles man, we're waiting
'05 Passat TDI - Ventectomy - BSM Delete - Nicktane Head with 2u Cat Fuel Filter - MaloneTuning Stage 1.5
'05 Mk4 Jetta TDI - Ventectomy - DG FMJ Panzerplate - HR Sport Springs and 28mm Rear Sway Bar - TT LCA Bushings -Nicktane 1u Fuel Filter - MaloneTuning Stage 1.5 ...for now
sirpuddingfoot is offline   Reply With Quote
Old April 25th, 2012, 12:30   #341
JFettig
JFettig's Avatar
Sorry, I have had misc things holding me up. I had to swap out the window regulator panel in the drivers door, the front doors gave me hell lining them up, the window regulator is now giving me hell so I need to go back in for a third time. I didn't 100% finish it but I'm driving it and its nice I might drop by to kill some time tomorrow if you are around and you can check it out in person.
Old April 29th, 2012, 19:04   #342
G60ING
G60ING's Avatar
I haven't done the front window regulators but after tearing apart the rear PS door to fix a lock assembly I've gotten pretty proficient at disassembling the rear doors...What a PITA the 1st two times. The 3rd time was a snap. Those plastic roll pins can be the make or break of what you think of the job. BTW 3 months after doing the lock the plastic roll pins pulled out and the window dropped. Putting back in was simple but this time I put some RTV on them to help slide them in and hold them in after drying.
G60ING is offline   Reply With Quote
Old April 29th, 2012, 19:20   #343
JFettig
JFettig's Avatar
Interesting, and I totally forgot to put those back in place on the front doors. That little bracket in the front doesn't really make much sense as to why its there. I'll see how much noise it makes tomorrow.
I finally got the front drivers regulator situated. Its the cheap aftermarket regulator I have in there, it didn't give me any grief until I put it in this new door. The glass actually fell off today right when I got home.
How does the rear door regulator panel come out? Last time I pulled the door card, I thought it was riveted to the door. You mention plastic rivets, I don't remember seeing this.
Jon
Old April 29th, 2012, 23:06   #344
G60ING
G60ING's Avatar
There was one rivot that needed to be drilled out on the rears. The plastic roll pins hold the window to the regulator.
The lock assemble has to be removed with the window regulator which requires you to pull the door handle.
There is a how to on www.passatworld.com that explains what has to be done to pull the regulator. It was a big help
Old May 4th, 2012, 08:25   #345
JFettig
JFettig's Avatar
A set of Rosten rods just happened to show up
Page generated in 0.18502 seconds with 10 queries
[Output: 127.65 Kb. compressed to 105.76 Kb. by saving 21.89 Kb. (17.15%)]
