Old February 19th, 2019, 11:33   #3391
Stealth TDI
Pre-Forum Veteran Member
Stealth TDI's Avatar
Hello,
Originally Posted by Lightflyer1 View Post
I love your trailer and the things you do with it!
Thanks! I'm starting to fix up my cargo trailer. Someone decided the weak aluminum fenders made great seats and bent one.
I replaced them with heavy plastic parts by Fulton. They're quite strong, but I still don't want anyone sitting on them. The "NO STEP" stickers were ineffective (can't fix stupid), so I'll try these bird deterrents that I already have on the baby trailer...
The black fenders stand out a bit against a silver backdrop. So I painted the upper and lower trim to tie-in the black. I'll eventually apply some sort of black decals. Here's how the trailer sits now...
I also made a few minor improvements to the interior...
I'm on the verge of installing electrical and ventilation systems to make the trailer suitable as a sleeper. After that, I'll have it wrapped to match my car.
| .M y . S t a g e . 2 . G T I . |
| Facebook | YouTube | Fuelly |
Stealth TDI is offline   Reply With Quote
Old February 19th, 2019, 12:00   #3392
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
I think that will get the point across. Nice looking project.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old March 1st, 2019, 14:22   #3393
brnsgrbr
brnsgrbr's Avatar
Fuel Economy: 44 mpg
Recommended brake controller? MK4 Golf.
Thanks in advance
Sent from my iPhone using Tapatalk Pro
2.0Ltr ALH w/BHWs, WB girdle, IE Tuscan rods, RyanP GtB2260Vk kit, 4bar MAP; Kerma 3" exhaust w/HF cat & Aeroturbine 3030XL, headwork, DRW 6speed w/DG Sigma shifter;SBC S2 End race clutch W/ferramic disk; Peloquin TBD; Bosio Stage 2 R520s; DLI Technik mounts ; 11mm; TT CA bushings; DG Panzer FMJ, RP,& 100K TB&SB upgrade; Coolant heater; DRL & EGR deletes; ventectomy; Accuair/Airlift suspension;B20-B100
brnsgrbr is offline   Reply With Quote
Old March 2nd, 2019, 19:07   #3394
Geordi
Geordi's Avatar
Location: Somewhere between Heaven and Hell. But it is really hot here in S. Florida...
I like that interior - all of the options, either rubber floor or the E-track or the carpet. NICE!
I always knew beans would give me gas. But I never expected Diesel!
Geordi is offline   Reply With Quote
Old March 2nd, 2019, 19:29   #3395
TDonovan
TDonovan is offline   Reply With Quote
Old March 2nd, 2019, 19:44   #3396
TDonovan
[IMG]//http://imgur.com/gallery/E1XbmQz[/IMG]
Old March 3rd, 2019, 05:19   #3397
bobbiemartin
Any of the proportional controllers would work fine. I use the Redarc Tow-Pro Elite Trailer Brake Controller on the Touareg and Tiguan. It works very well, but the main feature I like is the installation. The main controller can be tucked away behind the dash with only a knob to mount in the dash. Redarc sells various faceplates for the knob. On the Tiguan, I removed the dash light controller (I keep it a maximum anyway). I then sourced a spare dash lite controller, gutted it and epoxied a Redarc faceplate to it. Then I just snapped it in place of the dash light and it looks like it should be there.
bobbiemartin is offline   Reply With Quote
Old March 3rd, 2019, 09:00   #3398
PB_NB
PB_NB's Avatar
I use a Tekonsha P3 controller which has momentum monitoring and a bunch of other things.
Mine is mounted within reach on the bottom of my dash so I can reach the adjustments on the front and the activating lever on the bottom if I need to apply the trailer brakes without touching the car brakes.
TD Donovan, That looks like a fun build. How about the weight in the end, any predictions? What are you going to pull it with?
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old March 4th, 2019, 20:20   #3399
Stealth TDI
Thanks,
I've had to make some big changes. I took the walls down to do the electrical work, but found a few leaks. I also found some shoddy workmanship on the floor. So I pulled it up. From there, I decided to work on the roof to address the leaks. The roof is stripped clean and awaiting good weather for a seal-job that'll be top notch. I hope to do the things to rehab this trailer that the manufacturers probably should do during production.
Here's how the trailer sits now:
I'll do a write-up when I've finished it all and share a link here.
Scott
Old March 21st, 2019, 23:22   #3400
StevenR
TDI(s): 2002 Jetta
Default Serious Towing
I'm prepping (with a cargo trailer) to pull a twin axle travel trailer with my '02 Jetta. So far I have a Kerma 165 HP kit, stout clutch, coil spring air bags and a couple other mods. I can accelerate well up a 6% grade in 4th gear at 4,000 altitude (.658 5th gear, nope) with 3,800 lbs in tow. Heads turn for sure. If I could figure out how to post a photo and a video clip here, I would.
StevenR is offline   Reply With Quote
Old March 22nd, 2019, 03:29   #3401
jason_
Subbed for this. Haha. Awesome.
I bet people will look twice when they see that engine pumping juice and boost tugging that setup
Sent from my 2PS64 using Tapatalk
jason_ is offline   Reply With Quote
Old March 22nd, 2019, 22:05   #3402
Lightflyer1
Lightflyer1's Avatar
How to post pics in my signature. I hope you have temp gauges.
Old March 23rd, 2019, 08:07   #3403
dremd
dremd's Avatar
The issue that I repeatedly have when towing box boxes with the TDI is people pass the trailer and immediately move over in front of the trailer into the spot where you are. Horn seems to make it worse, swerving isnít brilliant when towing a largish trailer, so I recommend brakes.
Just something to be ready for.
Tesla Model S P85
03 Silver Premium Jetta Wagon ALH + 6speed MT
2013 Nissan LEAF Totaled
2006 Sprinter
2014 JSW (Went back to VW)
dremd is offline   Reply With Quote
Old March 24th, 2019, 19:07   #3404
DerekG
Fuel Economy: Towing:26-32.6 City:34-38 Hwy:45-54.2
Took the Grizzly out for ~35miles of 4x4 trails
Sent from my SM-N960U using Tapatalk
DerekG is offline   Reply With Quote
Old March 25th, 2019, 06:49   #3405
jason_
I want a 4wd atv, but they're just sooo huge.
Unnecessary!
I have a small 94 Honda 200 type ii four Trax utility and it's perfect size, just wish the front wheels had some power occasionally.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.20796 seconds with 10 queries
[Output: 132.00 Kb. compressed to 110.57 Kb. by saving 21.43 Kb. (16.24%)]
