Old December 28th, 2007, 08:45   #1
vw754
vw754's Avatar
Default handbrake adjustment
I could do with a handbrake adjustment on my car as when applied it works on a hill but on about 5 notches (too high) id like it to work on 3 clicks max. Discs are good as ar the pads,i think maybe the cables have stretched over the years,the car has done over 100k+miles.
I thort maybe you guys have done this or know how its done.
2001 (B6) A4 1.9 TDI 130BHP.
vw754 is offline   Reply With Quote
Old December 28th, 2007, 09:00   #2
AccountingTroll
AccountingTroll's Avatar
Fuel Economy: 54/49/45
Hmmm, an Audi B6 with a 130BHP TDI. I hate the US market. Why, oh why, can't we have that car here?
To answer your question, I have no idea. I've never been inside a B6 let alone worked on one. The fellows on the B5 forum might have an answer.
However, my gut says they are using the same ratchet mechanism that most other VW/Audi cars use. If you can figure out how to remove the boot and trim, your should see the cables attached to the mechanism with two 10mm nuts. Loosen the nuts and take up the slack.
Good Luck.
I am a Man,
But I can change,
If I have to,
I guess.
AccountingTroll is offline   Reply With Quote
Old December 28th, 2007, 09:16   #3
vw754
vw754's Avatar
Good Luck.
more complicated than the b5...2 bolt method.
Page generated in 0.11773 seconds with 10 queries
[Output: 54.55 Kb. compressed to 49.20 Kb. by saving 5.34 Kb. (9.80%)]
