Old March 23rd, 2006, 05:10   #1
jeromec
Default Difficulty shifting into Reverse gear after gear swap
Good Day
I have a 2002 A4 Golf IV 1.9 110 Hp TDI 5 Speed. 123 000 Km
pp520's, 0.68 5 th
I have extreme difficulty shifting into reverse gear. I have to select gear 5 first before reverse can engage. The selector moves easily at the gearbox end - I have applied grease, leading me to think that there are some bushes or something under the gear stick that could be the problem.
I changed my gear 5 form 0.754 to 0.681 and now when I engage 5 and tap on the fuel the leaver kicks back say 3~5 mm. Take your leg off the gas & leaver returns to normal engaged position.
Please assist. Thank you in advance
thank you in advance
Golf IV 1.9 TDI , PP520's,VR6 F/w, RC2/3 & 0.68 Fifth
jeromec is offline   Reply With Quote
Old March 23rd, 2006, 09:54   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
I can share my very limited experience from last week. I replaced a broken shift lever on mine. The Bentley indicated two different adjustments if the gears don't engage smoothly. One is on the outboard link (cable?) that controls front to back range of motion. The other one I didn't have apart, but I assume it's on the inboard which controls up and down range of motion.
hth
Old March 23rd, 2006, 19:28   #3
TurbineWhine
Fuel Economy: 56/50/39
I also have the .681 5th gear in mine. I did not notice any change in reverse or the other gears when I did my swap. However, mine has always been very hard to get into and out of reverse, especially when cold. It is still the same after the gear swap. Just a thought, are you sure you put the correct fluid back in? An incorrect fluid could make the shifting harder. Good luck on finding your problem. If it ends up being a cable adjustment, I might try adjusting mine to make it easier than it currently is. Let us know your resoulution.
TW
TurbineWhine is offline   Reply With Quote
Old March 27th, 2006, 12:35   #4
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Adjust the cables and reset the shifter. Follow Bentleys procedure.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old March 27th, 2006, 14:20   #5
weedeater
Fuel Economy: 54/43/38
Ditto.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Page generated in 0.11491 seconds with 10 queries
[Output: 64.78 Kb. compressed to 56.91 Kb. by saving 7.87 Kb. (12.14%)]
