Old February 20th, 2019, 06:07   #1
Classic
Default Glow plugs
I recently acquired a 2013 TDI Beetle... No where on the dash cluster is the display for the glow plugs. We are having a heck of a time starting in cold (below freezing) weather. In the manual there is a reference to them but again nothing on the dash cluster. Am I missing something?
Classic is offline   Reply With Quote
Old February 20th, 2019, 08:35   #2
Rob Mayercik
The manual should have a picture of the instrument cluster with all the warning/info indicators pointed out - that doesn't show where it should appear?
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is offline   Reply With Quote
Old February 20th, 2019, 08:47   #3
scooperhsd
SHould be a little pigtail.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old February 20th, 2019, 09:04   #4
Classic
I've scoured the book for a photo of the page...the only reference to the glow plugs is in the starting procedure... I'd show a photo of the page but I don't know how to attach a picture on this forum.
Old February 20th, 2019, 09:43   #5
oilhammer's Avatar
Fuel Economy: fantastic
The preglow lamp should come on when you turn the key on no matter what, hot or cold... just the length of time it stays on will vary based on how cold the coolant is.
So you are saying the lamp NEVER comes on? That is not right, something is wrong. I'd ask the engine controller, as it communicates with the glow controller, and see if a fault is present.
www.cardocautomotive.com
Old February 20th, 2019, 09:45   #6
Classic
Thanks for the words of wisdom...yes that as well as turning off all power draw before trying to start. Still curious about the lack of glow plugs indicator on the dash.
Old February 20th, 2019, 12:57   #7
Lightflyer1
Lightflyer1's Avatar
https://www.vwserviceandparts.com/se...icator-lights/
Left gauge just to the left of the EPC light.
How to post pictures is in my signature below.
Old February 20th, 2019, 16:19   #8
Classic
Thanks all...the glow indicator light DOES com on... Silly me. I will take the advice to shut off ALL accessories before trying to start.
Old February 20th, 2019, 19:27   #9
Mongler98
is it just an issue starting due to no glow plug warming time or is it sluggish to start after warming the plugs after 30 seconds?
Old February 21st, 2019, 06:13   #10
Lightflyer1
I am in Texas so not really cold here. That light comes on and goes out really fast here, even when the temp has been down to the 30's. You have to be looking for it or you will miss it. Here anyway.
Old February 21st, 2019, 16:42   #11
Ol'Rattler
Ol'Rattler's Avatar
Scan for DTC's (Fault codes). A local parts house will do this for you for free. Just don't buy garbage Chinese parts for your Dub from them. My best guess, look for a DTC relating to the CTS (Coolant Temp Sensor) which does regulate glow time.
Even if the dash temp gauge appears to read correctly, still scan for DTC's.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Glow plugs don't work, new plugs, new harness, new relay, good fuses Matthewsz TDI 101 19 February 9th, 2016 06:42
Glow Plugs here Glow Pugs there Glow Plugs every where tugman3461 VW MKIV-A4 TDIs (VE and PD) 17 December 3rd, 2010 18:38
Dealer: VW TDI's do not run Glow Plugs in after-glow mode-- start-up only SootFoot VW MKIV-A4 TDIs (VE and PD) 2 August 5th, 2009 17:25
WTB: Glow plugs and glow plug wiring harness (01 Jetta) TDI_NC Private TDI Items for Sale/Wanted 2 January 5th, 2006 08:02
best place to get Glow plugs? yes glow plugs TDikook VW MKIII-A3/B4 TDIs 8 February 14th, 2005 11:19
Page generated in 0.15314 seconds with 13 queries
[Output: 99.54 Kb. compressed to 83.74 Kb. by saving 15.80 Kb. (15.87%)]
