Old February 7th, 2019, 18:28   #1
gtrinker
Default Transmission - All Gear Lights On
About a month ago I noticed occasional rough shifting into low gears... very intermittent. Then came the slight lurch after stopping quickly. Today I hit the brakes on the highway as the bonehead on front of me stopped to cut across the median. When I accelerated, there was what felt like slipping. Then I noticed all the gears were illuminated on the dashboard (photo attached in case that seems confusing) . The car was revving high and not shifting to a higher gear. I exited, tuned off the car and back on and all was normal.
I was suspecting low fluid and needed to get to the shop to see if there is a leak and to check the level. Now I am thinking electrical issue. It is a 2005 TDI Wagon. I had a rebuilt transmission installed about 80K miles ago.
Anyone experience this?
gtrinker is offline   Reply With Quote
Old February 17th, 2019, 17:02   #2
JonnyObnoxious
JonnyObnoxious's Avatar
TDI(s): 05 VW Passat
Your transmission dropped into limp mode. Check your transmission control module for moisture. It's under the carpet on the RH side. Pull the fault codes and start diagnosing!
If it makes you feel better, mine is stuck in limp.
Sent from my SM-G930P using Tapatalk
JonnyObnoxious is offline   Reply With Quote
Old February 17th, 2019, 18:01   #3
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Yes - scan it and go from there. If it felt like it was slipping you probably need another rebuild.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old February 18th, 2019, 08:09   #4
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Limp defaults the car to 3rd, no? Would feel like slip from a start...
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old February 18th, 2019, 09:47   #5
oilhammer's Avatar
Fuel Economy: fantastic
4th or 5th, pretty sure it is 4th though.
OBD works, need to start there.
www.cardocautomotive.com
Always on cigarette plugs for radio gear/lights cowgirlkaboom Upgrades (non TDI Engine related) 3 January 8th, 2015 04:05
Transmission gear indicator steve2150 VW Beetle 2012+ 3 November 17th, 2013 19:03
Gear indicator lights flicker Heavy Duty VW MKVI-A6 Jetta Sedan (~ 2011+) 0 December 2nd, 2012 17:35
Gear Selector Display Lights Blinking Farff VW MKV-A5 Golf/Jettas 4 July 2nd, 2009 21:17
PRNDS Lights Flashing, Stuck in First Gear Tawny TDI 101 8 November 13th, 2007 15:20
Page generated in 0.15152 seconds with 13 queries
[Output: 69.44 Kb. compressed to 61.38 Kb. by saving 8.05 Kb. (11.60%)]
