Old February 11th, 2019, 13:55   #1
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
Default Rns 315 setup....
Working to understand and program my new to me 2011 JSW TDI with a rns315. I somehow keep muting am/fm/seius xm, randomly (not with the mute button) which locks out the volume knob control at random levels (no sound). I was able to reset to "factory settings" once. I bumbled it up again. eeerrrrr....
All else fails, manual time
JELLOWSUBMARINE is offline   Reply With Quote
Old February 11th, 2019, 15:41   #2
BarryT82
Are you using the steering wheel button or phone button to mute it?
BarryT82 is offline   Reply With Quote
Old February 12th, 2019, 10:53   #3
JELLOWSUBMARINE
The mute on the radio is not pushed. Just to confirm I toggled it to try all possibilities. Which reminds me the overhead mute doesn't seem to do anything. I read something in the past over concerns/lawsuit(?) regarding this? I have a 2011 w/ built in BT on the rns315. The article I read went over the BT modules. 2w9, 3w9, 7w9. All radios used a separate module under the pass. seat, except the rns 315. According to this article the 2011 MY used the better 7w9. Does this mean my 2011 rns315 has 7w9 built in BT is equivalent to 7w9 module
As far as the phone goes, when receiving calls should the radio auto mute/lower the volume?
Guess I need more seat time. The VW radio manual stinks
Old February 12th, 2019, 10:58   #4
JELLOWSUBMARINE
To clarify, the radio (fm only) would not unmute. I found and did the reset to factory settings, re-paired the phone. got a little way in setting channels and it did the no sound control thing before completion.
Old February 13th, 2019, 01:19   #5
BarryT82
You have those Bluetooth modules backwards. It’s 9w2, 9w3, and 9w7. There are different versions of the 9w7 that have more features. You would need to upgrade to a 2012 or newer radio to get those features and not all RNS-315’s have built-in Bluetooth. Beginning in 2014 only some had it.
Old February 13th, 2019, 02:53   #6
JesseTDI
Mine is a 12 and has bluetooth built in. To the OP's question, I have found that if I spin the volume nob 'down' quickly it mutes everything like you are describing, if you spin it quickly back 'up's it reverses the effect, hope that helps!
JesseTDI is offline   Reply With Quote
Old February 13th, 2019, 08:55   #7
JELLOWSUBMARINE
You have those Bluetooth modules backwards. Itís 9w2, 9w3, and 9w7. There are different versions of the 9w7 that have more features. You would need to upgrade to a 2012 or newer radio to get those features and not all RNS-315ís have built-in Bluetooth. Beginning in 2014 only some had it.
I beleive BT was an option so it does stand to reason that only some 315s have built in. Are you saying no built in unti 14?
I have a phone book but no previous calls or other features as far as I know. I cant seem to find any info on voice control. Probably a 9w2? Im used to a 2017 Subaru BT so I'm wondering if I should just go to an aftermarket. I had a 2015 Kenwood DNN992 in my Passat that was incredible
Old February 13th, 2019, 09:01   #8
JELLOWSUBMARINE
Thanks Ill try that
Is your 12 a 9w2,3 or 7 equivilant? Any voice command advice
Old February 13th, 2019, 15:21   #9
JesseTDI
Haven't looked into the version of the module in my car and a rarely use the voice command stuff. It seems almost exactly like the sync system that was in my 14' Ford focus (computer voice is even the same) but I never used that either so i wont be much help to you there.
Old February 13th, 2019, 18:46   #10
BarryT82
The early model 9w7’s didn’t have A2DP features. 2012+ have them. All RNS-315’s from 2011-2013 had built-in Bluetooth and only some 2014+ models have it.
Old February 14th, 2019, 21:42   #11
JELLOWSUBMARINE
The early model 9w7ís didnít have A2DP features. 2012+ have them. All RNS-315ís from 2011-2013 had built-in Bluetooth and only some 2014+ models have it.
A2DP is the 3.5mm aux input on the lower right of the unit, isn't it? My 2011 has that, I haven't tried it yet. The BT phone works great, better microphone. pickup than my 17' Subaru. Maybe because the interior noise control is excellent. Only thing I wish it had where several preset phone numbers.
I also have a multiple pin plugin attaching a short cable in the center console??? What's that about?
Got am/FM programmed but my 3mo (2/5 -5/5) Sirius xm is dead. Surprised at the decent sound on fm for none HD
Anyone have a list of voice commands?
Ill probably keep the rns315 and ad the camera. I miss my Kenwood in the old Passat TDI.
Old February 15th, 2019, 05:22   #12
BarryT82
Your 2011 radio doesn’t support A2DP when streaming music using Bluetooth. It won’t allow you to change songs with steering controls when using Bluetooth either. You need the newer radio for that. If you look under the passenger front seat you probably have a Bluetooth module. Your radio has internal Bluetooth, but it probably isn’t being used.
Old February 21st, 2019, 22:30   #13
JediJoker
JediJoker's Avatar
TDI(s): 2011 JSW 6MT
No. A2DP is a Bluetooth profile. My 2011 w/RNS315 has A2DP (stereo audio streaming), but not AVRCP (car display/control of Bluetooth audio).
- JediJoker
"Dieselgate" / 2011 VW Jetta SportWagen TDI 6-speed
JediJoker is offline   Reply With Quote
Old February 22nd, 2019, 02:14   #14
PRY4SNO
PRY4SNO's Avatar
Fuel Economy: Impressive
Your 2011 radio doesnít support A2DP when streaming music using Bluetooth. It wonít allow you to change songs with steering controls when using Bluetooth either. You need the newer radio for that. If you look under the passenger front seat you probably have a Bluetooth module. Your radio has internal Bluetooth, but it probably isnít being used.
Can you offer a PN for the OEM radio required to "change songs with steering controls when using Bluetooth?"
I have a 2010 and want to know, as my head unit crapped out and need to source a replacement.
- 2010 GSW 6 speed TDI (304k km & counting): #farmenwagen
- 1992 Audi 80q 20v: the 20vt winter sled (long term project)
- 1990 Audi Cq 20v: #becauseracecar
PRY4SNO is offline   Reply With Quote
Old February 22nd, 2019, 07:48   #15
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
post a pic of your cable... The end will determine what plugs into it. typically they have the older iphone/ipod plug. it's for playing music..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
RNS-315 too RNS-510 HELP!! HighVoltageTDI VW MKVI-A6 Jetta Sedan (~ 2011+) 1 April 10th, 2017 06:52
RNS 510 vs RNS 315 Stitch2015 VW Passat Family (NMS and B7) TDIs (2012+) 7 January 24th, 2016 09:00
rns-315 to rns-510 BMKruse VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 May 11th, 2015 17:15
Swap rns-315 for rns-510 madrukus VW MKVI-A6 Jetta Sedan (~ 2011+) 5 July 24th, 2014 06:33
rns-315 to rns-510 help BMKruse VW MKVI-A6 Jetta Sedan (~ 2011+) 3 March 17th, 2013 09:01
Page generated in 0.11225 seconds with 13 queries
[Output: 129.41 Kb. compressed to 108.20 Kb. by saving 21.22 Kb. (16.39%)]
