Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old February 6th, 2019, 19:48   #1
Seansf49
Default Just got a 2012 TDI
Excited to join the forum after my purchase of a 2012 Jetta TDI! Got it from a dealer with 64k on the clock, new brakes and tires and fluids all around. I couldn't be happier with the purchase. They have a few kinks to work out sunroof is squeaky, trunk seems a bit floppy and the TMPS light won't come off despite trying to reset it but the dealer really seems to be taking care of any issue with these cars. There were a few other options with less miles but this one is pretty loaded and the service record was perfect. Bought in NM, stayed in NM throughout the process and serviced on time at every interval. Excited to start my journey to 300k!
Sent from my ONEPLUS A6013 using Tapatalk
Seansf49 is offline   Reply With Quote
Old February 6th, 2019, 21:43   #2
ToBiN
ToBiN's Avatar
Fuel Economy: 33 - 36 mpg stock
Congrats on the purchase. I had a 2011 White, M6 with 170k when I turned it in. I always wonder if I will see that car again. They are fun to drive. Enjoy!
ToBiN is offline   Reply With Quote
Old February 8th, 2019, 11:46   #3
nacskins
TDI(s): 2012 Jetta
lol I just purchased the exact same car! very pleased so far.
nacskins is offline   Reply With Quote
Old February 8th, 2019, 12:37   #4
Graham Line
Filling tires at one of those digital air compressor stations solves the TPMS light problem for me.
Drop all of the tire pressures several psi below normal, set the air pump to 38 psi, reinflate all of the tires, and reset the low tire warning light. The machine does a better job of inflating all 5 to the same pressure than I can do with a hand-operated gauge.
Filling station guys switch the air to 'free' because I buy 99% of my diesel there.
(Fifth tire is a full-size spare on a matching road wheel. Too much driving in the boonies for a compact donut, and the 'real' spare fits perfectly in the well).
Graham Line is offline   Reply With Quote
Old February 8th, 2019, 22:42   #5
Seansf49
Dropped it back by the dealership. They had to swap out the switch for the tpms and fix a couple other things I noticed over my first few days of having it. Getting it back tomorrow so we will see how it goes.
Old February 11th, 2019, 08:50   #6
andreigbs
Congrats and welcome!
You'll find a ton of information in these forums from those that have come before you, so whatever your potential issues may be (knock on wood, none), rest assured others have likely experienced them and the answer to the solution is to be found here.
Search is your friend, but it does take some getting used to. The sheer amount of volume of material to read will seem daunting, but in my 14 yrs of being a member I can say I've learned a little something from every thread I've read. In the end, your TDI will thank you and your dieseling experience will be better than most (that is, if you prefer knowledge and wisdom instead of ignorant "bliss" like so many seem to).
The TPMS issue is no biggie; perhaps the batteries in one (or more) of the sensors is bad or they buggered them up when replacing the tires. Let them figure it out and fix it on their dime.
You don't say whether it's a 6M or a DSG; if DSG, I'd make sure the service records indicate a transmission service was done at/around 40K miles.
Being that it's a 2012 model, hopefully you are on a recently replaced battery.
The trunk issue sounds like the typical Mexican build quality/assembly experience, where little rattles are difficult to isolate and remedy. In many cases it turns out the spare tire isn't fully tightened down in the trunk, or other bits are loose in the spare tire wheel well area.
As long as the powertrain, suspension, brakes and body are good, these little niggling issues can be fixed in time (often on your own for free). There's no reason why you shouldn't make it to 300K miles just fine.
Drive more, worry less
2014 Jetta TDI // 20xxx miles // 39 MPG & 2014 GLK 250 // 88xxx miles // 37 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Old February 11th, 2019, 19:26   #7
dpcass90
Fuel Economy: TBD
Congrats on the purchase. I just got my first Jetta TDI this weekend. They are awesome cars. I have the same gray color as your car which I think looks awesome.
dpcass90 is offline   Reply With Quote
Old February 11th, 2019, 21:34   #8
Seansf49
Thanks for the info! The car has a perfect service history and was serviced at the same dealership I purchased it from. It has a dsg that was maintained at 40k. It has a new battery, brakes and tires all around. They swapped out the switch and replaced the trunk hinge as well as a few other things. I honestly couldn't be happier with the car. I've never driven anything quite like it. It makes me sad there won't be more in the future in the US from VW.
Old February 12th, 2019, 07:08   #9
andreigbs
Originally Posted by Seansf49 View Post
snip... I honestly couldn't be happier with the car. I've never driven anything quite like it. It makes me sad there won't be more in the future in the US from VW.
That's great news then, happy motoring in your future.
And yes, it is said to think VW may have ruined small passenger diesels for the foreseeable future with their emissions scandal. Who knows what other manufacturers (Hyundai, Toyota, Honda, Mazda, etc.) might have made it over here to compete.
Trade a 2012 Passat Sel TDI for a 2011 or 2012 Toureg TDI Exec Ronvanb Private TDI Items for Sale/Wanted 0 February 21st, 2013 08:50
doing research TDI JETTA 2012 found this Consumers report looking to Buy a 2012 TDI hobokenkid General VW Discussion 38 June 12th, 2012 14:09
2012 GTI wheels on 2012 Golf TDI? iRG VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 12 March 21st, 2012 10:55
Can 2012 TDI Golf use some 2012 GTi suspension parts? TDiZombie TDI 101 1 February 29th, 2012 13:19
Comparison: 2012 Sonata Hybrid vs 2012 Camry Hybrid vs. 2012 Passat TDi F8L VW Passat Family (NMS and B7) TDIs (2012+) 22 February 26th, 2012 09:33
Page generated in 0.14683 seconds with 12 queries
[Output: 93.20 Kb. compressed to 80.46 Kb. by saving 12.74 Kb. (13.67%)]
