Old July 4th, 2015, 20:18   #1
gmcjetpilot
gmcjetpilot's Avatar
Default Back Up Camera Options - Camera Options
Anyone install backup camera? I notice some Garmin GPS models have backup camera option, wireless through Bluetooth to GPS. I'm using an Android smart phone and Google Map and Waze for Nav/traffic... works good, but still want backup camera.
There are wireless WIFI backup camera transmitters that work with iPhone and Androids. They are not too much money, transmitter and camera for under $80.
With that said does anyone have ideas, pictures of how to install the backup camera. Looking at eBay there are some VW backup cameras that seem replaces the license plate light cover and replaces it for one that has camera built in.... I assume the wire runs through there into car, saves from having to drill a hole I assume. That seems to be a slick setup....The pop up VW emblems are for sale but doubt they work with my year model. Anyone know if OEM or aftermarket can retro-fit, works here?
Edit: Below are the two options I am looking at. The license plate light insert or hatch lift handle insert, these seem best place to install camera. I believe the OEM back up camera is in the handle. Price for these are $25-$35... The transmitter I found with best ratings is shown below, comes under different names, typically Audio-Vox, SunroadTek, ePark, and others for about $45. It is Wi-Fi based and runs on a Android or iPhone App.... Total about $80. Garmin blue-tooth Backup camera works with some of their GPS, cost is $180 add on, not including the GPS price. The main complaint is the Garmin has low resolution and some lag, good not great. Since I am going to smart phone for GPS duties, the WiFi setup is best....
gmcjetpilot is offline   Reply With Quote
Old July 5th, 2015, 19:45   #2
galexandr
TDI(s): JSW 2012
I have the JSW with RNS-315 and installed the OEM Rear-view camera. You can learn more from this thread:
http://forums.vwvortex.com/showthrea...1#post86789097
Here is the item i got off ebay: http://www.ebay.com/itm/290916460617?rmvSB=true
Hope this helps!
galexandr is offline   Reply With Quote
Old July 6th, 2015, 11:19   #3
johnmharte
I'm running the OEM kit, bought mine on Amazon. I actually have another one in the box that was for a friend with a JSW that never needed it.
Mine worked well for about 8 months but now logs an error from time to time shows black screen on the head unit. I pull the errors on my VCDS scans. Not sure what is going on but I have the pano leak to fix first.. might be water intrusion related.
Super simple to install so long as you have VCDS.
johnmharte is offline   Reply With Quote
Old July 10th, 2015, 00:21   #4
gmcjetpilot
I don't think the radio I have has the capability for backup camera. I suppose I could buy a used one for not a lot of money. I would not mind getting the 510 with nav. I think I can upgrade for not too much money.
Thanks for the advice...
I found another option, even cheaper option. A dedicated mini LCD color monitor ($15-$25). This could be hard wired (very cheap) or for a few bucks you can get a video transmitter and receiver pair (2.4Ghz) for $8..... video.... the camera $12-$19 would make the total cost about $50 for dedicated rear view camera.
I do have a Garmin 2598LMTHD GPS which has the camera built in, but the dang camera, transmitter and receiver is $180... no thanks. However it would use the same display as the GPS and be automatic with reverse or parking lights.
Old February 7th, 2019, 11:54   #5
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
I know this is an old thread but do you still have the extra set up? selling?
thx
JELLOWSUBMARINE is offline   Reply With Quote
Old February 7th, 2019, 12:22   #6
johnmharte
I actually do! Just moved to FL and have it in my garage. DM me if you want to buy it.
Old February 7th, 2019, 13:08   #7
ToBiN
ToBiN's Avatar
If JELLOWSUBMARINE doesn't buy it, I am interested.
I too found the Amazon kit. Car has Nav so it should be plug and play. Do you need VCDS to enable the backup camera?
Thanks.
ToBiN is offline   Reply With Quote
Old February 7th, 2019, 14:45   #8
johnmharte
VCDS required, from a post in a different forum which worked for me.
Step 9: VAG COM Coding
Reconnect battery!
Go into either the radio or navigation (same thing) and click "coding" followed by "long code helper" and enable bit 6 on byte 3 (pictured)
Old February 8th, 2019, 01:28   #9
BarryT82
If you buy a radio with the coding enabled you don’t need VCDS. You can use the RCD-510 with camera input, RNS-315, or RNS-510. I have a few RNS-510’s and an RNS-315 available and can code it for you.
BarryT82 is offline   Reply With Quote
Old February 8th, 2019, 09:16   #10
ToBiN
ToBiN's Avatar
@johnmharte
so did JellowSubmarine pick up the kit from you or no?
Old February 8th, 2019, 16:10   #11
JELLOWSUBMARINE
Originally Posted by ToBiN View Post
@johnmharte
Just got the message
IIl pm next
Old February 10th, 2019, 11:40   #12
JELLOWSUBMARINE
@johnmharte
I am considering aftermarket so deal is still available
Old April 24th, 2019, 22:15   #13
Hydesmith
Fuel Economy: Trying to keep it around 5 litres/100k, at least on longer drives
My radio died in my 2011 JSW, so I bought a used radio from a 2015 JSW and had VW recode it ($$). The old one did not support reverse camera, but the new one does. Each time I put the car in reverse, it tells me that the camera is not available, so now I am motivated to install a camera. I may try to find one from a wrecker, but if there is an aftermarket that's cheaper, that would be good. Or a basic camera with some sort of adapter to fit the radio.
Hydesmith is offline   Reply With Quote
Old April 26th, 2019, 03:33   #14
BarryT82
The kits are about $106 on eBay. They ship from a China but arrive within a week. Iíve installed three of these on my vehicles and a few for others.
Old April 29th, 2019, 08:52   #15
KeyTDI
I bought the ToGuard 8" Dashcam/Mirror/Reversing Camera combo. $100.
Like it a lot so far.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
KeyTDI is offline   Reply With Quote
OEM Back-Up Camera w/o Reverse? Stealth TDI VW MKVI-A6 Jetta Sedan (~ 2011+) 2 May 25th, 2015 17:37
Back up camera for 2013- RCD510? Cayman VW MKVI-A6 Jetta Sedan (~ 2011+) 2 July 2nd, 2013 17:19
DVR/Camera/VDR Options Ben1000 Upgrades (non TDI Engine related) 7 September 4th, 2012 21:06
Integrated back up camera drywaller VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 1 April 10th, 2012 10:58
RNS510 NAV back-Up Camera securityguy Upgrades (non TDI Engine related) 3 August 10th, 2011 17:13
Page generated in 0.17343 seconds with 13 queries
[Output: 129.24 Kb. compressed to 108.19 Kb. by saving 21.05 Kb. (16.29%)]
