Old January 16th, 2019, 17:57   #18826
aslspiderman
aslspiderman's Avatar
TDI(s): 98 Jetta
Fuel Economy: Really good!
Originally Posted by red16vdub View Post
Look good,
only issue I see is having the gauges sit so low, requiring you to take your eyes off the road.
Now that I have it all hooked up, I agree, it's too low. Eventually I'll move it to the pillar, along with an EGT and maybe an oil pressure gauge. Just wanted to get it installed. Now I know how much boost I'm making
98 Jetta, K03/04, 520 sprints, aligator chip, SRS, torsion bar, Billy HD's, TT bushings VR6 clutch, GLX seats
aslspiderman is offline   Reply With Quote
Old February 7th, 2019, 18:36   #18827
garreth5
TDI(s): jetta
Installed a new battery and spark plugs. Then I ordered american racing wheels in 18x8.5 size.
garreth5 is offline   Reply With Quote
Old February 8th, 2019, 03:41   #18828
Spark plugs? What the hell are those?
2002 Jetta wagon, 384K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 260K; 2011 335d, 60K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old February 8th, 2019, 04:50   #18829
SoKYTDi
SoKYTDi's Avatar
Fuel Economy: See my signature!
Mostly just looked at it and wished the weather was warmer so I could pull the transmission and fix the (probably) borked shift forks...
I miss my car.
Just a Geek, trying to make his way in this world.
2003 Golf GL TDi -- Lots o' mods and a whole list of dreams..... now in 6 gears!
SoKYTDi is offline   Reply With Quote
Old February 8th, 2019, 11:14   #18830
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
I think they are like a pacemaker for engines that wont stay running on their own??
Today my Skoda turned 290000km, celebrated by making a to-do list for this year. Timing belt change, front rotors and other misc small stuff.
nokivasara is offline   Reply With Quote
Old March 1st, 2019, 13:36   #18831
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Noticed a growl from the rear and a few clunks that were unaccounted for over the last couple days...Got home, jacked the car up and found this.
https://youtu.be/ONj1mO_wEX0
Local NAPA had an SKF bearing and ABS sensor on the shelf so $110 and about an hour later we're back on the road (safely).
Can't complain, almost 300k miles and over 30K with a trailer. Hope the new one lasts as long as the old one.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is online now   Reply With Quote
Old March 4th, 2019, 08:29   #18832
FJ40Jim
FJ40Jim's Avatar
TDI(s): '01 Golf GLS
Fuel Economy: 44-52
Last week, I fired up car for a couple minutes of warm up & seat heater time before wife drove to work. After startup, and turning on seat heater, heater temp to max (engaging heater glowplugs), parking lights & radio, noticed idle was surging, lights flickering and there was a squeak from under hood. Determined OAD pulley was failing under heavy load. It was a crappy reman alt from Autozone.
Replaced with better (?) reman alt & OAD from CarQuest. Also changed tensioner assembly because of bad damper.
Now it charges fine, idle is smooth, and tensioner with new shock absorber runs perfect.
Jim C
01 Golf GLS TDI 5M RC2/3 racepipe Sprint520 5BL vented VDOgauges VR6coils BilsteinHD TTbushings lifted 215/55ZR16 hitch mufflerectomy yadda
FJ40Jim is offline   Reply With Quote
Old Yesterday, 19:23   #18833
TDIBaltimore
I gave a bath
TDIBaltimore is offline   Reply With Quote
Old Yesterday, 19:36   #18834
romad
romad's Avatar
Originally Posted by TDIBaltimore View Post
I gave a bath
I only gave mine a shower (I drove it in the rain!)
The fleet:
romad is offline   Reply With Quote
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
Page generated in 0.45472 seconds with 12 queries
[Output: 95.79 Kb. compressed to 82.32 Kb. by saving 13.47 Kb. (14.07%)]
