Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > TDI Cars for Sale/Wanted
TDI Cars for Sale/Wanted VW TDI/Diesel cars for sale and wanted.
Old January 26th, 2019, 14:26   #1
DieselGuy84
Default 2005 Passat for sale south Florida, bad trans
The good:
-B5.5 with PD TDI
-BORA PARTS Balance shaft delete kit installed
-18 inch motegi wheels (stock outer diameter times, don't rub and speedometer is accurate, GPS verified)
-suspensions is tight, never been lowered, tracks straight
-Led headlight bulbs (low and high beam)
-Comes with used serviceable steering wheel, driver window mechanism, still has under car engine splash shields
-aftermarket replacement new turbo cartridge included, not istalled
-added oem rear seat package tray sun shield
The bad:
-Transmission is shot, it was fine until a few months ago when I parked it, it refused to shift into 5th, it also lost reverse. I limped it home, figuring I had lost a solenoid or something. I pulled the pan. Fluid was clean for 200000 miles. No metal in the pan, changed the fluid (pentosin 1058206), tested and cleaned the solenoids (all triggered, and had acceptable continuity). Put it back together, same problems, but now you can hear a more pronounced chatter when reverse is selected. I think a clutch must have come apart, but not totally disintegrated. (Hence clean fluid) now that it has sat for a while, it slips in all gears, and the indicator shows all gears selected (limp mode)
-oil leaks from intercooler pipe junctions
-i have used the same oil as in my truck (valvoline premium blue extreme) having read some more, I realize this was probably not the best stuff for a TDI.
-DS rear door lock sticks on outside (needs to be locked and unlocked a few times to open).
-1/4" chip in windshield
The ugly:
-Dark colored florida car: clear coat peeled
-Interior is a little dirty
-headliner is falling down
-door panel vynil becoming unglued
-steering wheel has worn spot, foam is showing (used replacement included)
-tint has aged badly
stay tuned for pictures
DieselGuy84 is offline   Reply With Quote
Old February 6th, 2019, 22:40   #2
Mike in Anchorage
Mike in Anchorage's Avatar
Still hoping for pics . . .
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
2005 Passat bad trans - what is it worth? jdtdi VW B5 Passat TDIs 14 December 9th, 2017 08:10
2005 TDI Passat for sale. Needs trans. $2000 ALutz45 TDI Cars for Sale/Wanted 2 August 27th, 2017 14:33
Feeler 2005.5 Jetta TDI South Florida Cabbie TDI Cars for Sale/Wanted 10 October 1st, 2012 10:21
For sale 2006 Jetta South Florida VWSHPFRMN TDI Cars for Sale/Wanted 6 June 10th, 2012 13:49
2005 Jetta Sedan GLS - South Florida ADW_squared TDI Cars for Sale/Wanted 1 August 20th, 2010 07:28
Page generated in 0.10853 seconds with 13 queries
[Output: 54.10 Kb. compressed to 50.06 Kb. by saving 4.04 Kb. (7.47%)]
