Old December 7th, 2016, 01:57   #766
UhOh
UhOh's Avatar
Originally Posted by oprn View Post
Same here! I just found this site and thread, lots of good info but wondering if it's possible to get a little carried away looking for the "right" lube.
My experience started in '83 when I bought a Ford Escort a when draining the tranny discovered the factory fill was ATF. Did some inquiring, yup that's normal.
At the time I had a VW Rabbit that was extensively modified and putting out around double the stock power. Good test I thought and in went the ATF. What a difference in cold weather! And zero shifting problems in hot weather. No reliability or wear issues found. I actually still have that car.
So Dextron II has been my fill of choice ever since with the only problem encountered is the tendency of it to find weak seals and gaskets and seep a bit.
It's not about getting carried away, it's about getting something that works for you.
For me I decided to research with the notion of getting something that would work w/o having to spend the time and money to be doing a bunch of fluid changes trying to get the best fluid. And it's pretty clear what the top candidates are for 02Js (as well as what NOT to use- I have yet to read anyone that's happy with VAG's G070).
UhOh is offline   Reply With Quote
Old February 6th, 2017, 04:16   #767
SteelyTed
WoW, what a thread.
2002 Jetta TDI -5speedswap (daily driver), ventectomy, scangauge II, VAGCOM various other vehicles.
SteelyTed is offline   Reply With Quote
Old May 10th, 2017, 22:56   #768
bembasound81
Hi guys,
I actually read most of this thread. I either missed it, or the info was not clearly stated. I have a 2006 Polo TDI BNV JCZ transmission. In 2007-2008, the car had a service action (as they call it), and they replaced the gear oil. Part number used: G052512S0. As I found out, this is an internal part number. We can buy it as G052512A2. At around 100k km, I bought gear oil from the dealer - part number G070726A2. At around 200k km - same part number. I didn't pay any attention to the part number. I thought they will sell me what the car uses...
What do you think I should buy now: G052512A2 or G070726A2. Does anyone know for sure the difference between the two?
I'm thinking about this because I have 2 different noises from the gearbox:
1. something like "hhhhh" when under 0C, at first start in the morning. it stops when the clutch is completely disengaged (everything in the gearbox stops). if it's only half, sound is still there. after 5-10 min of driving, the sound goes away. If over 10C, sound is not present.
2. after wellwarmed up gear box, when over 20C in the air, just before the car comes to a complete stop, so 1-2 km/h, it makes a knocking sound but not continuously - it's like the sound can be heard every 45 degrees of the wheel. car can stop and the noise may or may be not present ( depends on where the wheel or driveshaft stops). if the noise is present, it goes away if trying to engage 3rd or 4th gear without pressing the clutch, or if turning the steering wheel !! it also goes away gradually if pressing the clutch. if the car stops and the noise is not present, I can be heard if turning the steering wheel.
if there was a gearbox issue, why is it affected by the turning of the steering wheel?
the car has no abnormal noises when driven: hard accelerating, hard decelerating, turning hard uphill, breaking hard downhill and turning.
someone gave me the idea of checking the tapered coned bronze ring from the flanged output shaft that comes out of the diff, and when doing so, I will put fresh gearoil in. now, what should I use G052512A2 (the service action oil) or the G070726A2 (the oil that the dealer would sell me now according the VIN) ?
Thanks!
bembasound81 is offline   Reply With Quote
Old May 18th, 2017, 23:03   #769
bembasound81
just put in G052512A2. Obvious smoother shifting (25 Celsius outside) cold and warm. I expect the lever to move like through honey in the winter for the first 10-15 min but I won't mind.
When I took out the filling plug (car leveled), about 100-150 ml of oil bursted out, so that confirmed my "suspicion" that I did overfill the gearbox, which is good .
When refilling, I tilted the car for about 10-15 degrees, and it took about 1.8 - 1.9L of oil before starting to overflow. Then I put the filling plug back in quickly so I guess I overfilled it also this time.
difference between G052512A2 and G070726A2: G052 seems to have a bit darker colour. At room temp, to the naked eye they seem to have the same viscosity.
Old May 19th, 2017, 06:35   #770
Chris B
Fuel Economy: 54/48/40
I've been running the G070 in my '02 for the last 60K at least. I just rolled 300K miles, and she still shifts great. It shifts much better when it is cold (0F or less especially) and all-around I like it better. The only "issue" I notice is when fully warmed up, I will will get a little bit of grind when shifting into reverse if I do it to quickly after depressing the clutch. If I wait an extra second to let the input shaft spin down, it won't.
Chris
2002 Jetta GLS Wagon 5spd, Indigo Blue, Grey Velour, Cold WX pack, E-codes, E-switch, 310K+miles.
"Good drivers have dead flies on the side windows." (Walter Röhrl)
Chris B is offline   Reply With Quote
Old July 2nd, 2017, 23:21   #771
New Mickey
The user formerly known as mickey
TDI(s): 2015 Passat
As always I plan to use the Amsoil product. As always, if it causes a problem you all will be the first to know.
-mickey
New Mickey is offline   Reply With Quote
Old July 13th, 2017, 10:12   #772
UhOh
UhOh's Avatar
Chris
Makes sense that that thinner fluid (which the G070 is) will work better in your colder climate. If you haven't tried Pennzoil or the AC Delco fluids I'd say try them as you might find that you have ZERO issues (warm or cold). BTW - I missed the mention of what fluid you'd replaced. Keep in mind that in almost all cases a fresh fluid will always be better than old fluid.
Old September 25th, 2017, 17:57   #773
blacksi
TDI(s): Jetta
My 2001 finally failed at 450k miles 5th gear went out and I never changed the fluid it was original. Every bushing was worn out and sloppy as hell. I put a junk yard 130k tranny in it which feels so much tighter, but I put Mobil 1 fluid in it and it grinds like crazy. I'm going to pick up some OEM stuff this week and give that a try. I'm kicking myself for not just leaving it alone from the junk yard, but if something went wrong I'd be kicking myself too.
blacksi is offline   Reply With Quote
Old October 21st, 2017, 01:56   #774
stevegrass777
https://cdn.opieoils.co.uk/pdfs/mill...-75w80-GL5.pdf
https://www.millersoils-shop.co.uk/t...0-gl5-gear-oil
At 100°C it’s 8.7 I have put it in a 5 speed Passat and seems to change gear very well and seems quieter, going to put it in my Audi 6 speed it’s gl4 and gl5 not worried about that.
stevegrass777 is offline   Reply With Quote
Old September 7th, 2018, 19:58   #775
3L3M3NT
3L3M3NT's Avatar
For everyone out there looking for less expensive option for the factory G 052 171 A2 02M/02Q transmission fluid, I've finally come across a few good options in my search on what oil to put in my 02M transmission.
I also think I've figured out who makes the factory fluid for VW/Audi and that would be Febi/Bilstein.
Anyway here are the less expensive options I've found:
FCPEURO @ $8.22/L for Febi/Bilstein Oil
Warehouse33 @ $9.77 for Febi/Bilstein Oil
PelicanParts @ $10.75 for Febi/Bilstein Oil
This is for you guys in the UK:
AutoDoc @ 9,92 Pounds for Febi/Bilstein Oil
AutoDoc @ 11,80 Pounds for SWAG Oil
AutoDoc @ 13,61 Pounds for Meyle Oil
Here's another option that people have mention they thought this company may be making the OEM fluid for VW/Audi's 6 speed transmission oil and that would be Fuchs.
https://www.carid.com/fuchs/titan-si...52-171-a2.html
And last but not least, I'm going to giving Liqui Moly High Performance Gear Oil (GL4+) SAE 75W-90 a chance and see how it does in my transmission with a Wavetrac differential, even though Wave trac recommends Motul Gear 300 75W-90
Believe it or not, I was able to find the Liqui Moly gear oil for only $10.91 on ECS Tuning. https://www.ecstuning.com/b-liqui_mo...ter/20012~liq/
Hopefully this will help some people out in the future and I believe this will also work for the 5 speed guys out there as well, since I see it lists G070726A2, 0019892603, G060726A2, G052512A2 on site as what this oil will cover.
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
October 19th,2019 Cruise/GTG in Sturgeon Bay, WI
3L3M3NT is offline   Reply With Quote
Old September 15th, 2018, 17:24   #776
tikal
Fuel Economy: 37 MPG (~ 45% city)
Thanks for the extensive research in the list below. Another one made in the USA that I am using in my 2004 Passat (manual conversion) with great results:
http://www.bgprod.dk/wp-content/uplo...1/792_SPEC.pdf
tikal is offline   Reply With Quote
Old September 16th, 2018, 21:32   #777
3L3M3NT
3L3M3NT's Avatar
I'm glad I could contribute and hopefully it saves others some money in the future by not having to buy OEM fluid from the dealer, since last I checked it was in the $26 range.
That BG Syncro Shift II looks like a good option as well. Where do you purchase it at?
For reference--->https://www.bgprod.com/catalog/drive...ncro-shift-ii/
Firefox fix
RTDI Build Thread
Old December 2nd, 2018, 19:00   #778
arnoldkul
Originally Posted by Dimitri16V View Post
For Euro vehicles , use Motul Gear 300 or Castrol Syntrax
Hello is Castrol syntrax V FE 75w-80 or Syntrax Transaxle 75w-90 on my 2001 mk4 ALH engine 5spd. 02j code EGR manual.
I'm in Europe BTW.
arnoldkul is offline   Reply With Quote
Old March 17th, 2019, 02:24   #779
stevegrass777
I’ve used Millers trx synth gl5 and gl4 in a 6 speed Audi a4 b7 and a passat b5 5 speed both manual in the UK.
Both change gear really well and slightly better fuel consumption.
I chose it based on the viscosity in the product sheet was close to what has been tested here.
In the uk on ebay you can get 5 litres for less than £40 so its quite reasonable too.
Great stuff in my opinion.
Cold shifting was mush better than original altho original had about 160,000 miles on it.
http://www.millersoils.co.uk/product...-75w80-gl5/604
Old August 29th, 2019, 08:47   #780
Smontana16
TDI(s): 2015 Golf
Default Anyone try this yet
https://www.redlineoil.com/mt-lv-70w75w
Smontana16 is offline   Reply With Quote
B4 - Bentley says G50, ETKA says G52 Diesel_Aggie VW MKIII-A3/B4 TDIs 8 May 19th, 2017 07:26
G50 v. G51 v. G52 dieseldorf Fuels & Lubricants 17 May 18th, 2017 23:02
G52 in 02J DQY jcrews Fuels & Lubricants 5 November 20th, 2007 10:42
G52 vs G55 dhdenney Fuels & Lubricants 2 September 18th, 2007 06:39
Should I stick with OEM Auto Tranny Fluid? stancho TDI 101 7 December 11th, 2006 21:28
Page generated in 0.21885 seconds with 13 queries
[Output: 139.03 Kb. compressed to 118.28 Kb. by saving 20.75 Kb. (14.93%)]
