pkhoury
That guy with the goats
After fixing my leaking fuel lines a few days ago, I was meaning to check the air filter (of which I didn't have a spare handy). Anyways, I noticed a different whistling when revving the car from idle to past 2400 or so. Today, while coming back from the lumber store, the car had little power and at one point, I heard something pop and saw a lot of smoke come out the rear. Pulled over, didn't see anything out of the ordinary in the engine bay. Car kept going, but definitely limp mode and I couldn't get over 65mph.
Checked the air filter and half of it was soaked with diesel. Changed that out, and took the car for a drive down the road. Limp mode is still on, no CEL at this point. Then a CEL pops up with the usual "emissions workshop" message. Checked it when I got home, and I get this:
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
I'm hoping I didn't damage the turbo. I did some searching and there are references to N75. I'm not at all familiar with checking vacuum lines, actuators, etc. Could I have inadvertently destroyed the turbo, or could it be something else that's still fixable? I also noticed that even in first gear, if I go about 50% on the throttle, it starts rolling coal around 3000 RPMs. It didn't do this before. I also hear the exhaust louder, as if I were running it full load up a grade, when I'm on a level surface.
The turbo is roughly 30-35K miles old (VNT17).
Freeze Frame:
