Technician!
Anyone in Michigan (preferably near Lansing/Jackson) have this tool so I can program a new key for a 2003 Jetta? Would rather support a fellow member than spend $$ at the stealership.
Thanks!!
Thanks!!
I think Vag-Tacho's two main things is PIN reading and changing the mileage.^ vag tacho is to read the SKC.
I took it as the OP has a new key, and needs the SKC for programming, so VCDS wasn't enough.I think Vag-Tacho's two main things is PIN reading and changing the mileage.
I bought a VAG401 on Amazon for this...it was the cheapest and easiest solution at the time. I have one of the Vag-Tacho clones...but I've not tried it. It came with a box full of other VW junk that I bought. I also have a Vag K-Commander...which worked...sort of. It did half of what I needed it for, and not the rest.
As for the OP's request, won't VCDS do what he needs?
Yes, right...sorry. I remembered programming my keys using VCDS, but I forgot that I had my PIN code for that already.I took it as the OP has a new key, and needs the SKC for programming, so VCDS wasn't enough.
What do you think of the VAG401?
I would like to just get rid of my immo on my 2002 jetta tdi, but not sure how I would go about it and what is the $60 method. thanks EDCould always immo delete for less than $60 and be done with it for good.
^ yes for remote programming, which has nothing to do with what he's trying to do.
he needs to program the immo to start the car. never mind the remote programming. he needs a key that can actually start and run the car.
The drivers only work correctly on 32 bit computers. So you would need an older laptop.i bought one last week and kept effing with it, wouldn't connect. i sent it back and should have a replacement in about a week or so. if it connects and everything works as it should, you are welcome to use it for free. if it doesn't... you're still welcome to use it lol
Yes !!!!! It's true !!!! It's because the people behind this plagiarized software are actually Russians working for Vladimir Putin !!!!!CAUTION: EVERY copy of this software I've ever seen has had a horrid trojan in it. If you load that on your computer your machine WILL get hijacked. The only "safe" way to do it is to set up a virtual machine image, load it, use it and then DESTROY said virtual machine (or wipe the disk you loaded it on in the first place.)
When i bought my cable from ebay it came with a CD rom that did not have the virus. I have experienced the same problem with online downloads.Yes !!!!! It's true !!!! It's because the people behind this plagiarized software are actually Russians working for Vladimir Putin !!!!!
Not only that..... they are in cahoots with North Korea !!!!!
