Bob S.
Charlie; Thanks for sharing.
How much is the emissions system replacement going to cost?
The shift points are made to be at a lower more "diesel" rpms, and less of a Gasser rpm.I understand the dyno test results, but after test driving several phase 1 fixed DSG GSW's the last few days I feel they are not as potent as my unfixed 15 GSW DSG, don't know what it is but mine have always felt much more powerful, not disputing the results but its just my observation so far.
This is great news, though it is puzzling that the VW engineers back in 2013-2014 could not find this balance. I was told ~14% more DEF usage after the "EPA tune". Can you clarify...for your viewing pleasure.
Same dyno, same car, obviously different days.
It seems to have GAINED power and torque after the dieselgate reflash!!!
before dieselgate update:
139 hp, 258 ft-lb
After dieselgate reflash:
146 hp, 271 ft-lb
net approx gain:
+7hp, +13ft-lb
these are NOT tuned files, 100% stock to stock comparo. everything about the car is 100% stock.
4500 ft altitude and SAE correction, sea level curve will be a slightly different shape.
Discuss.
Our's (pre fix compared to post fix) is noticeably different. Not disputing dyno results but ours feels down on torque, not at tip in clutch engagement, it's actually better. Significantly down on torque, HP in 5th, 6th especially when car has more than 2 people in it. Very disappointed, ours is going back specifically due to poorer performance and uncertainty over phase 2 fix.I understand the dyno test results, but after test driving several phase 1 fixed DSG GSW's the last few days I feel they are not as potent as my unfixed 15 GSW DSG, don't know what it is but mine have always felt much more powerful, not disputing the results but its just my observation so far.
Question please.Our's (pre fix compared to post fix) is noticeably different. Not disputing dyno results but ours feels down on torque, not at tip in clutch engagement, it's actually better. Significantly down on torque, HP in 5th, 6th especially when car has more than 2 people in it. Very disappointed, ours is going back specifically due to poorer performance and uncertainty over phase 2 fix.
So why not get it tuned and back to the way you want it?Our's (pre fix compared to post fix) is noticeably different. Not disputing dyno results but ours feels down on torque, not at tip in clutch engagement, it's actually better. Significantly down on torque, HP in 5th, 6th especially when car has more than 2 people in it. Very disappointed, ours is going back specifically due to poorer performance and uncertainty over phase 2 fix.
j
I drive this way most of the time.Also it is very common in many diesel applications for a tuner to change fuel mapping to strongly encourage you to shift to a gear with lower rpms to save fuel and utilize the tq inherent to a diesel...
.....snip....
Since VW needed to keep the same mpg post fix, I bet they did a bit if this.
Fix... simply shift to maintain a lower RPM.ypu might not FEEL like you are going as fast cause the engine is not screaming, but you are.
The Honest test for this is the new DSG programming where it tries to keep the lower rpms longer by holding on to gears with lower rpms, and it shifts sooner.
Me, I let the dsg do its' thing...and it has done great. The performance and mpg speaks for itself IMO.
MAYBE you need to drive it at lower rpms than you were. Yes, as engine tech changes, so do driving methods.
essentially this is correct in principle if not 100% technically accurate.Pull the egg out from behind the pedal and I bet they scoot just as well as the mk6's.
I really want to but am hesitant so early on. There's a Malone Tuning tuner 30mins from house so its soooooo tempting.
Once I go down that path...when is enough going to be enough??
Mwahahahah!!
May I ask a question please?.....snip....
I'm indifferent to the warranty. If I change my mind about it I can always have it reflashed to stock before taking it to the dealer, not that they'd necessarily notice.
And with this car I think a tune only will be enough. I'm not up for making hardware changes.
ThxProbably depends on the tuner, and if these cars can be flashed with a loader. Don't know the answer to that.
Either could be true, so it's not a matter of honesty as much as it is optimism. Since I don't intend to bring my car back for the second phase of the fix I'm not concerned.The tools used by all of the big north american diesel tuners are the same. Your flash counter will change if flashing in any way other than bench flashing, which can void your warranty and VW will know that something is up. There's the "we haven't had any problems with this you'll be fine" approach, and then there's the "VW will know the car has been modified and might void your warranty approach"
I'd rather say the latter and be honest.
Can only speaking for me.The tools used by all of the big north american diesel tuners are the same. Your flash counter will change if flashing in any way other than bench flashing, which can void your warranty and VW will know that something is up. There's the "we haven't had any problems with this you'll be fine" approach, and then there's the "VW will know the car has been modified and might void your warranty approach"
Can you skip part II?... I don't intend to bring my car back for the second phase of the fix I'm not concerned.
