Overdrive0902
New post for new issue. For those of you that have viewed the: https://www.google.com/url?sa=t&rct...476021&usg=AFQjCNGU5ZBdNjzzI_IQYyILOn3EKqn-8g
Current codes:
(Instruments)
01039 coolant temp sensor - open or short to plus intermittent
01314 engine control module - no communication intermittent
The problem:
At start up the idle raises to about 35-4k RPMS in a matter of seconds. It would probably redline if I let it.
Brief history:
Previous owner did not take car of it. Head failed shortly after I bought it, and my intentions were to rebuild and daily drive it.
I replaced with a new AMC head w/timing kit, good compression, new injector nozzles Bosio dlc 520, nictane fuel filter kit, new Mahle vnt-15 turbo, egr/asv delete, pd150 intake mani, buzzken 2.5 turbo back exhaust. I double checked the mechanical time (GOOD). Following all of the new parts the car would start after bleeding the injectors but smoke white (diesel smell at idle), Adjusting the IQ made no effect, and timing graph (yellow line) was to advanced to graph. I eventually drained the fuel tank and added fresh fuel, changed the IP head seal and QA seals, bled the injectors and now the revving rpm issue has started....
Experiencing the symptoms listed on ROSS-TECH
http://wiki.ross-tech.com/wiki/index.php/01039
I also replaced the Coolant Temp Sensor (green) with no change. I deleted the codes but they come back instantly. I am currently chasing the wires to find a fault, but everything looks good so far.
Possible Diagnosis:
1. Bad wire/ground somewhere on the circuit
2. Injection pump is going out
3. leaking or bad injector
Fuel does not make sense because there is no code associated with the issue. Open or short is just like saying the sensor is unplugged.
Any Gurus feel free to speak your opinion.
Current codes:
(Instruments)
The problem:
Brief history:
Possible Diagnosis:
