Mapachurro
Evening everyone,
This is my first time posting because, as I'm sure you can believe, this community and its awesome resources have helped me resuscitate my 2003 Golf from something two steps from the grave to... Well, a few more steps from the grave. It's got 315,000 on the body, and about 120,000 on the engine. There's things that need work, but the body's in great shape and it still gets close to 50mpg on the highway, so...
I am trying my best to wrap up my first solo timing belt job, but the damn thing won't start. Tonight I went through the process:
1. Put the camshaft lobes up in first position, loosen the tensioner, pop the cam sprocket off, put the IP pin in, rotate the crankshaft until it's at TDC at the mark (this is a manual, so it's the notch, not the little circle thingy), lock that down.
2. Put the cam sprocket back on, loosen the IP bolts, tighten the tensioner, check the crankshaft, still good, torque down the camshaft bolt, tighten the IP bolts, remove all the locks.
3. Crank through 2 full camshaft rotations by hand, all good normal compression, bump the engine a few times, try to start up. I get no goods; I hear a deeper thumping than I'm used to hearing, or maybe that's just the normal compression, but usually it's covered up by the higher-pitched combustion so I never notice it as such.
Here's the kicker: I get out of the car, take the valve cover back off, put it lobes up, and I can still insert the IP pin and the flywheel notch is TDC. So... What am I missing here?
Additional considerations:
-I'm not entirely sure that the crankshaft didn't slip a tooth or two while I was torquing down the camshaft bolt, but the fact that after I tried starting the car, they're aligned, seems... Odd.
-I have the car up on ramps. Can the angle produce this non-start?
-I've been working on it for about a month, as it also needed MAF/turbo vacuum line troubleshooting, so it hasn't started in that long. I've tried sitting there turning the key on and off to prime the pump, in case that's a problem...?
-I don't have the harmonic balancer back on yet, nor the serpentine belt
-I don't have the air system fully put back together when I tried this start--so, like, the pipe going from the EGR to the intercooler is still off.
Last but not least, if I have to throw up my hands in despair, is there anybody in Cleveland I can take this to? The closest TDI specialized mechanic I know of is in Columbus, most of the folks around here, in the words of my neighborhood garage, "Politely say thanks but no thanks to diesels." Literally.
Thanks in advance to any help!!
