Ryan_B
Hello all. I am hoping I may find some help from fellow TDI owners. I have a 2006 Jettta TDI BRM Engine code. I'm finding out that the turbo's in these are rare and interesting beasts. I found that my car was going into limp mode occasionally at low rpm. Further investigation lead me to the Turbo and I found that the actuator was not holding vacuum. Further investigation and I found that not only it is very difficult to get that thing off while the turbo is still installed, the part itself is as rare as hens teeth. Then I found that IDPARTS appears to have taken an actuator for a different turbo and built a bracket to make it fit on this one. I found another vendor who copied that and I purchased that and replaced the actuator.
I followed the below video for setting the unit up.
https://www.youtube.com/watch?v=6fBR5hcDc08
The OBD reader shows that I have this code now P2564. Something about turbo vane voltage low. I am assuming I did not get the adjustment correct. But adjusting this takes two people as I have to come up from below the car to get at the bottom nut. There just is no room coming from the top. It's really a terrible design. So, before I try to adjust it again, does anyone know if the code means the actuator is bad electronically (new one holds vacuum and I see it move down when the car is started) or if I need to make adjustments. And if I need to make adjustment, which direction? It's such a pain to do I want to get it right asap...
I do have a VAG-COM cable coming I bought from Ross Tech. Is there something I should get into the diagnostics with that to make changes somehow?
Thanks for any help / Insight you could provide.
~RyanB
~RyanB
