Heroineshero
Hi peeps! I've been mostly just reading but DOH, this problem certainly need some help from yall.
My AVF 130 bhp -03 Passat variant boosts randomly: sometimes it works like it should, sometimes it boosts past 3-4k rpm (or even higher) and sometimes it wont boost at all. Restarting doesn't help at all.
I had codes for fuel temp sensor and MAP wiring and after I fixed those and cleared codes my engine light went away but the problem still exists.
I did replace all the vacuum lines, N75 (due broken nozzle), clean and bypass the EGR -system http://uk-mkivs.net/topic/50427-pd-vac-line-simplification-n18-n239-valve-delete/ clean every sensor and did the mr.muscle trick twice (tho I'm not sure if the foam got to the turbo since i put it in from the EGR pipe.)
I had emissions and engine lights on, but now they are gone, no new codes.
I'm getting a bit desperate.. any ideas, tips or tricks I should try?
