nhdude
- Joined
- Jul 11, 2005
- Location
- New Hampshire
- TDI
- 2011 JSW 6M gone back to VWoA, 1996 Passat Wagon (RIP)
So, I got the CEL and dreaded P0401 code yesterday for the second time in the past few months. Reading previous forum posts suggests that this is a very bad thing as in cracked DPF when accompanied by soot in the tailpipes which I also have. 83000 miles... out of warranty of course.
Would appreciate input from others who have experienced this and what solution is needed. Is it DPF and EGR filter replacement only or does everything downstream from the DPF also have to be replaced? What cost might be expected?
This is a 2011 JSW 6MT purchased new in January of 2011. It has seen the dealer only once since then for a software update. All regular maintenance done by me as per recommended schedule.
Needless to say, this makes me most unhappy :-(
Thanks in advance for any words of wisdom! Log attached below FYI...
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 DA HW: 03L 906 019 DA
Component: R4 2,0L EDC G000SG 8217
Revision: 12H07--- Serial number:
Coding: 0050072
Shop #: WSC 01128 444 19779
VCID: 6DD1331274473949B56-8038
1 Fault Found:
001025 - EGR System
P0401 - 001 - Insufficient Flow - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 133173 km
Time Indication: 0
Date: 2015.03.09
Time: 13:41:49
Freeze Frame:
RPM: 1955 /min
Speed: 116.0 km/h
Voltage: 14.29 V
Load: 89.8 %
Load: 100.0 %
Mass Air / Rev.: 490.0 mg/str
Mass Air / Rev.: 495.0 mg/str
Readiness: 1 1 0 0 0
Coding: 0050072
1 Fault Found:
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 133173 km
Time Indication: 0
Date: 2015.03.09
Time: 13:41:49
Freeze Frame:
RPM: 1955 /min
Speed: 116.0 km/h
Voltage: 14.29 V
Load: 89.8 %
Load: 100.0 %
