ThewifesTDI
Will 15" wheels fit a '12 JSW TDI? I searched, & found out they will fit a Jetta sedan, but I don't know if the TDI Sportwagen has bigger brakes, or something. Ordering winter tires, & thought I should check.
Go look at your spare tire that should give you the answer you want.
having said that, no, 16's are min requirement.
I think the lower weight will help with rotational mass and lower the gas mileage as a result.Where did I read that there is a certain rim size that gets superior gas mileage?
But that's not a TDI. My understanding is the TDI wagen has larger brakes than the gas-engined version.Just test-fitted 15" B5 steelies onto a 2.5 liter 2009 Sportwagen. Perfect fit, no clearance issues with the brakes.
