kreibach
My Jetta brakes work great. They're in stock config. no issues. My desire is to get my 2003 suburban to work like that. Specifically the time between when you slam on the brakes and when they are at max braking is short in the Jetta and Looong in the chevy. Love this forum for my Jetta. I wish there was one like if for chevy. I've replaced the booster with no change. I haven't replaced anything else yet. But they've always worked like that along with most Chevy's I've known.
Online research is unfruitful on this topic perhaps due to the complexity or liability involved. It appears to be an OEM specialty that only they will touch.
I find this from section 5.2.1 of Brake Design and Safety (3rd Edition) ISBN 978-0-7680-3438-7:
The booster response time should be less than 0.1 second to reach the saturation point in the event of a rapid brake application with pedal travel rates at 1 m/s (3 ft/s).
The Jetta seems like it achieves that. The Chevy takes a painfully long time. In emergency braking I'm doing a leg press on the pedal while the pedal takes it's sweet time to go down to max braking no matter how hard I press.
Any pointers to anything anywhere?
