MORTAMIR
Yup!!
And how do you fit that on an 05?Depending on the tune with the suggested upgrades that 3LEM3NT suggested I think that 200 is more realistic goal if you throw in an 11mm pump which adds a little more response to the overall response.. I am about 170 with a much smaller turbo and PP764 nozzles set at stage 1 flow for minimal smoke and a RC3 tune.. The GTD1752 will be my next upgrade along with a FMIC.
Like dual-plugging a Hardly-Ableson; drill the injector hole on the other side of the valves for the VE units, I don't see any reason to remove the PD units. Use silicone tubing to hook up the injectors to the pump...And how do you fit that on an 05?
Dang my shortsightedness, i am all in on that solution, not sure why i didn't think of that myself.Like dual-plugging a Hardly-Ableson; drill the injector hole on the other side of the valves for the VE units, I don't see any reason to remove the PD units. Use silicone tubing to hook up the injectors to the pump...
cheers,
Douglas
