m3_madbimmer
So I am getting the fault for intake flap / anti shudder valve and I acquired a new one. Installed it and still same fault. I checked fuses and they are ok. I then took apart old flap and applied battery power and ground to verify that it is indeed ok. So I am assuming something with the wiring or perhaps the ECU is bad. I inspected all I could of the wires/harness/connector and all looks good for me.
Can anyone point me in the right direction of which pin on the 6 prong connector is power and which one is ground. I am assuming it is ground side switched by the ecu?
