MEgearhead
Can anyone provide some information on how to reset the readiness monitors on a 2015 Audi Q7 CNRB 3.0 TDI?
All but one is completed (the last one or bit 7 of byte 4).
I have not been able to find any information that specifically applies to the 2015 model. I have technical bulletin 01 15 18 dated Jul 20 2015. Available here: https://static.nhtsa.gov/odi/tsbs/2015/MC-10123033-9999.pdf
However this information does not seem to be correct for model years 2014 or 2015 based on the years indicated in the bulletin. Also, the MVBs given in the bulletin do not correspond to any measuring block available in VCDS.
Is there a bulletin for the newer models? I have gone through the almost impossible driving cycle in the 09-13 CNRB bulletin multiple times, with at least one forced regen while driving, and have managed to clear all but the last one. I have also performed the EGR test and the Automatic test sequence in Basic settings.
Thanks for any help
Thanks for any help
