drehenkraft
Hi Club,
I’m chasing down a big coolant leak on the driver’s side of the block, flowing water on the little shelf under the thermostat as soon as I pour water in. After replacing the thermostat/housing/o-ring which was at least part of it as the o-ring was hard and cracked, it appears that there is also a leak coming from the coolant hard pipe that exits the block right near the thermostat. I found post 41 in this thread for the A4
http://forums.tdiclub.com/showthread.php?t=132193&highlight=coolant+pipe&page=3
and it helped me get started, but now I’m at the point where the BHW engine varies from those A4 types and I’m stuck. Or more correctly, the hard pipe is stuck.
I have everything unattached from the hard pipe, the back end of it came off easily with the pull-up metal clip on the plastic connector (needs a new o-ring there, too, if someone knows that part number or size) and I removed the fuel lines and clips and a couple of bolts from the tabs that come off the hard pipe to hold it in place. I've also removed the dipstick tube for some room (and to keep from cracking it) and so now I can rotate the hard pipe but can’t seem to get it to come out of the hole in the block when pushing the pipe towards the back of the car. Before I use full force and or some kind of leverage (and possibly break something) is there a trick to getting this pipe out of the block or is there some hidden locking mechanism I can’t see somewhere?
Also can anyone confirm the o-ring part number for the block/front end of the hard pipe? My search says 06B 121 687 but not sure if that’s really for BHW.
Thanks!
Thanks!
