borjawil
2006 1.9L Jetta, 200K miles. I replaced the cam and lifters about 30K ago. Started to blow black smoke (excess fuel?) a couple weeks ago. Changed oil and now its blowing white smoke. Oil level ok, not overfilled. Tends to do it after driving a few miles once it gets warmed up. Burning smell, not sweet.
DTC for erg circulation gasses. Forget the exact code. Pulled the EGR and there was some build up. Decided to pull the intake and there is some build up there as well. Will get it cleaned out.
While under the vehicle noticed there is a decent amount of oil on bottom of engine and other parts. Driver side up near turbo and down to the axle gear box is all dry black soot. Any ideas on this? Vacuum leak possibly coming my issue? No exhaust leak from what I can hear. What do I need to check and how do I check it? Figure Ill just replace all the vacuum lines to be safe.
