Old January 7th, 2018, 13:13   #1
TDITim83
TDITim83's Avatar
Default B4V Roof Rack Capacity
I am wondering if there is any info on roof rack weight capacity. Any info on that would be great
TDITim83 is offline   Reply With Quote
Old January 7th, 2018, 15:30   #2
Mongler98
probably no more than 50? lbs. i have a heavy duty all aluminum rack on my 2004 ford escape and its max limit is 100lbs I could not imaging that it would be more than 75!
I remember seeing that mythbusters episode were they confirmed that a MK3 Jetta could hold that 3,000 lbs of building materials. Im sure it could handle 100 but i would not drive it with that much on it! Have you ever seen the damage from a kayak getting ripped off? i have, saw a car totaled from a $400 kayak on a $50 kayak rack mount on a stock roof rack.
Point is, if you have to ask, the answer is no, you have too much on there!
Old January 7th, 2018, 17:50   #3
ToddA1
Fuel Economy: Dismal
From the 96 owner's manual, each cross bar can carry 88 lbs., when the load is distributed evenly. Roof load must not exceed 165 lbs.
The roof rails have depressions, where the cross bars should be mounted, avoiding the sunroof, if equipped.
This may have been the first time I ever opened the owner's manual....
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old January 7th, 2018, 18:15   #4
Steve Addy
TDI(s): 97 Mk3
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old January 7th, 2018, 20:08   #5
Mongler98
DAM, 165 lbs? thats nuts, My extra heavy duty ladder rack for my 2 ton work van is only rated at 100 lbs each. No way a 3600 lb MK3 car has a higher rated roof rack vs a 4,800 4x4 SUV. Not saying your wrong but i think thats crazy high for a roof rack for a small car. I would never load more than 100 lbs on that thing if you are going over 20mph.
Old January 7th, 2018, 20:22   #6
TDIDaveNH
Left Lane Coal Roller at Large
TDIDaveNH's Avatar
TDI(s): 1997 Passat
165lbs??? That's it? SMH wish I had pictures of the stuff I've hauled aloft.
Per cogo, non per mico (By compression, not by spark)
GLX conversion in Storm Grey- my first TDI engine rides again.
TDIDaveNH is offline   Reply With Quote
Old January 7th, 2018, 21:36   #7
Mongler98
im sure it could hold up 300 or even 500 lbs. the issue is slamming on your brakes, or hitting the gas or cornering. the weight is trying to pull the rack off the car in a shearing force, not a lateral load into the body and suspension. this last summer i had 40 lbs of 2x4x16' on the roof rack of my van. had to SLAM on the brakes and i still bumped into the back of the jackass who was on his phone, even though i had 3" strap ties crossed and around the bundle, the load shifted enough that 4 boards shot out from the middle of the stack and went though the back of the dipsh!ts window. i was loaded properly and i was not cited as at fault by the adjuster but it happened as i was going 55 and had to stop in like 50 feet. The guy hit the person in front of him, he was not texting, he had his phone taped over the airbag and was still playing the movie when the cops got there. i love my 2 ton as NO damage was done to it. Point is, its about what the load will do to the rack, it could just take the rack with it if you where in a situation like i was.
Old January 8th, 2018, 07:00   #8
TDITim83
TDITim83's Avatar
wow, was not aware of the limit. Ok, glad to know. I'm only going to have a small cage up top for trips and maybe a water proof bag for storage.....alot more secure and can hold some more bulky stuff. Family of 4 and the back is not massive
Old January 8th, 2018, 12:17   #9
Steve Addy
TDI(s): 97 Mk3
Post is for B3/4 wagons with factory roof bars, not Mk3.
I think you should go and review your work van ladder rack info, my guess is that it's rated more than that, i don't see how it wouldn't be, 100 lbs (200 total rack both sides) is not that much.
Steve
Old January 8th, 2018, 12:38   #10
Mongler98
and i well aware of his car make when i commented.
actually the set i got is not rated that way. its all about the roof line.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
After talking with some experts on this, the ideal max load on most aftermarket racks like this is 100 lbs each. They are extended a good bit and sag because i put way to much load on them from time to time but the van is not that fast. It was a 1 ton but i upgraded a few items to get 2 ton capacity out of it (according to the truck guys i helped with)
Old January 8th, 2018, 13:49   #11
Steve Addy
TDI(s): 97 Mk3
I was just clarifying, it appeared, based on your comment, that you thought he was talking about a Mk3 when the title to the thread clearly says "B4V Roof Rack Capacity."
As for the van load bars I queried and picked about the first thing I came to and this is the description:
"Our steel cross support ladder rack will easily support up to 850 lbs. -- distributed evenly on the ladder rack."
And that comes from here which is at American Van dot com. It's also THE cheapest roof rack they have too if that means anything and it's only two uprights not three.
I stand by my claim that 100lbs per load bar for a van rack is pretty weak, IDK who your 'experts' are but that is really a weak load bar unless they're made from bamboo or something similar.
Steve
Old January 8th, 2018, 17:45   #12
Mongler98
what part of "Depending on the roof line" dont you get. Also you need to read u p on what i have been saying. im sure i have put over the max load i should have on them, they are beefy. 800 lbs on any rack can easily snap the bolts right off if you were to have a collision.
You could probably put over 1,000 lbs on each point that they mount to the van, but the moment you hit the brakes HARD or bump into the rear end of some other car, any stopping force would be enough to shear the sheet metal off whatever its on.
I have been hauling loads on the top of my van, escape, my 10 foot, and my 25 foot trailer. i have been though a few road hauling safety training courses mandated by a previous employer. I know what im doing when it comes to hauling and making sure a load is as secure as the driver. I am telling you that if i put 850 lbs on the top of that van or ANY rack that was not DESIGNED to carry that in an impact that you are going to kill someone when your load comes flying off when you slam into a car in front of you, or have enough braking and traction to stop fast enough. those 40 lbs of 2x4x16, was only a few of them and the ones in the center FLEW OUT of the stack. i had 3x 3" ratchet straps holding them down properly. ones at the front and back go over and around the bundle compressing it. Roof racks can only get so tight on the straps before they bend or damage the roof. they were plenty secure. there was about 50 pictures that was taken as i have commercial auto and it must be well documented. i was cleared as having them secured in "overkill" as described by the adjuster. Still it flew out from the center and right into and though the back glass of the jerks car in front of me.
its not about weakness, its about a rack that can stop a load from shifting or ripping its self off the car.
The ones i have also are a tube in a tube design and they flex ALLOT.
Old January 9th, 2018, 01:18   #13
Abacus
That helpful B4 guy
Abacus's Avatar
Doesn't the Ohio State Police department have pictures?
The B4V rails are through bolted to the car in a few places with reinforcements on the roof line. It's not going anywhere.
I've had 5 bikes on the roof totaling about 150 pounds going for hours up the interstate at 80mph and it never felt flimsy. It did feel like dragging a parachute and resulted in my worst ever fuel mileage, just over 36 mpg.
Even having the crossbars (with or without the wind deflector) decreases my mileage by 3 mpg, and having two bikes up there drops me by 6-8 mpg. Just something to consider. I switched to a hitch rack for that purpose but still use the roof rack to transport more than 2 bikes or the kayaks.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old January 9th, 2018, 09:26   #14
0die
I'm hauled a lot of sh*t on my roof rack...probably well over the "limit"
I have 4 cross bars...a pair of Thules and a set of Subaru bars...
I should probably removed them unless I'm hauling stuff...I wonder how much MPGs I'm losing...
1996 Passat wagon TDI
assorted gas powered crap and motorcycles
RIP...countless Mercedes, Isuzu and other random diesels
0die is offline   Reply With Quote
Old January 15th, 2018, 20:05   #15
TDIL3dad
Anyone with an OEM Mk3 Votex luggage basket they want to sell?
I have the B4 OEM cross bars 3A9 860 019 and looking for the matching basket.
Cross bars have a channel grove and correct Mk3 basket will have swivel feet, square or rectangular shaped that fit the channel groove.
pls send PM.
TDIL3dad is offline   Reply With Quote
FS: Tiguan roof rack cross bars (for cars with roof rails) 5N0071151 blackice168 Ontario 0 December 12th, 2013 19:08
5x100 Steelies, Thule Roof Rack with Bike Rack, and Misc. Stuff fisherdanski Private TDI Items for Sale/Wanted 1 October 3rd, 2013 22:35
For Sale: Original Vw Roof Rack W/lock & Key: Thule Roof Bike Rack pal99 Private TDI Items for Sale/Wanted 12 September 9th, 2009 13:29
wtt/fs new Thule roof rack/want a b4v rack BolaB4V Private TDI Items for Sale/Wanted 1 May 7th, 2009 20:51
SOLD- OEM VW GOLF ROOF RACK with SINGLE BIKE RACK WI_TDI Private TDI Items for Sale/Wanted 8 September 8th, 2004 21:39
Page generated in 0.19929 seconds with 11 queries
[Output: 129.37 Kb. compressed to 108.47 Kb. by saving 20.90 Kb. (16.16%)]
