Old January 10th, 2018, 09:31   #16
Matt-98AHU
Matt-98AHU's Avatar
I think a compression check is in order.
Also, run a basic setting 04, post the results here. That at least can show us if the pump has adequate case pressure by proving it can adequately control timing advance.
Is this engine still all original? Original pistons?
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old January 10th, 2018, 09:34   #17
Matt-98AHU
Matt-98AHU's Avatar
What stinks about the 1Zs is the pistons. I mean, yes, they can go hundreds of thousands of miles with seemingly few issues, but most of them eventually seem to develop piston slap in #3 first, and score up the cylinder walls a bit, even on well-taken care of engines.
AHUs and ALHs don't seem to do that with the updated pistons they come with... But there definitely is a pattern failure of the #3 cylinder on 1Zs as they get up there in mileage.
Old January 11th, 2018, 13:11   #18
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
check the IP harness, I remember having to repair that due to age at one point and I believe it gave me goofy IQ readings and idle
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old January 11th, 2018, 21:44   #19
Abacus
That helpful B4 guy
Abacus's Avatar
I repaired this once already since it was a swapped pump. I thought of that and it checked out ok.
The turbo is blown, so once I get back from vacation I'll toss the 442,000 mile original one back on and send this hybrid back to Bora for diagnosis as to why it failed at under 12k miles. Needless to say, I am anything but pleased but we'll see what becomes of it. I don't beat on my cars, never abuse them, and you can bet it was installed properly and primed before initial use. Aaron and BoraParts are good people though, so we'll see what happens.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Abacus is online now   Reply With Quote
Old January 12th, 2018, 09:31   #20
KLXD
My '98 developed a lopey idle, timing jumped all over the graph, idle IQ jumped randomly from maybe 2 to 9, surged like crazy at parking lot speeds and even a little at highway speed on a very slight downhill. The injector balance was off but I don't recall it being as bad as yours.
Drove it like that a long time while trying to figger it out since it drove ok so I don't recall the mileage or if the symptoms came on gradually or all at once.
Anyhoo, the fix was a another pump. The replacement had broken insulation on the timing solenoid so I swapped that with the original pump. This would seem to exonerate that part as the cause of the original problems.
Haven't gotten around to opening the old pump up to see if there's anything obvious wrong with it. During the troubleshooting I checked all the usual suspects that folks suggest including a set of new nozzles balanced by DBW.
Got a spare pump to try?
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old January 15th, 2018, 16:12   #21
ToddA1
Fuel Economy: Dismal
I’m confused.... was the rough running and odd injector balance caused by a damaged nylon fuel line?
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old January 23rd, 2018, 08:49   #22
Lenard
Fuel Economy: Managing 44mpg with .220 nozzles, on stock turbo and tuned for .208s lol
Abacus, I am going to assume you've already performed a ventectomy? After fresh timing, injectors, vacuum lines, dynamic and static timing good to go and some wire repairs at the IP harness, I was still battling a lumpy idle. I was also having trouble fueling the car. So I gutted the vent button and used some hose to physically push the vent flap open. Lumpy idle has disappeared and now I can fuel my car! I thought it was crazy how simple the fix was, but also crazy that it turned out to be the last thing you'd think would ever make your car run like poop.
1998 Jetta AHU 5 speed SOLD @240Kish
2005 Jetta BEW auto. SOLD @208495K exactly.
1983 Jetta Diesel Coupe 4 speed. SOLD at ? Miles
1997 B4 Passat 1Z 5 speed. Mileage? Current diesel toy
Lenard is offline   Reply With Quote
Old January 23rd, 2018, 13:54   #23
Abacus
That helpful B4 guy
Abacus's Avatar
-Todd
No, the issues are on 2 different cars. Both are currently down.
I did a ventectomy about a decade ago, but thanks.
Old January 23rd, 2018, 16:22   #24
Lenard
I assumed you had done it already. You seemed to have looked into most logical answers so I figured I'd give you something stupid to try lol. Kind of like the "did you try unplugging it and plugging it back in?" thing
Old January 23rd, 2018, 18:50   #25
Abacus
That helpful B4 guy
Abacus's Avatar
It never hurts to help, and sometimes the simple things are often overlooked. Thanks.
Old January 24th, 2018, 20:45   #26
Lenard
Have you got it figured out yet? Curious as to what caused it
Old January 25th, 2018, 03:48   #27
Abacus
That helpful B4 guy
Abacus's Avatar
I've been on vacation in Mexico and am currently sick with the flu. Im swapping turbos this weekend and will report back.
Old January 25th, 2018, 19:45   #28
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Take care of yourself with this flu that's running around. It's pretty bad and hard to get by.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old January 26th, 2018, 23:01   #29
Steve Addy
TDI(s): 97 Mk3
That's not good, as aja8888 mentioned it's a bad one going around from what I understand.
Since I don't react well to vaccines I don't get them, but if I'm somewhere and I start to hear a lot of coughing I do an about face and head for the door.
Also I hear the vaccine for the current version of the 'plague' is not very effective anyway, something like 32%.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old January 27th, 2018, 03:42   #30
Abacus
That helpful B4 guy
Abacus's Avatar
My wife is a doctor and she said the vaccine is only 6-10% effective this year. Apparently the WHO chooses the combination of strains that makes up the flu shot and they changed their decision making paradigm yo try and increase the effectiveness. They chose poorly.
I don't get one either but she mentioned early in the season that I should due to battling a respiratory illness last year. She recently said I shouldn't bother getting one.
But I'm trying the same thing: avoidance. Not sure it's working too well.
P1592 rough running suddenly countrykid TDI 101 8 December 7th, 2017 17:38
Running issue and injector balance Turbodude1 VW MKIV-A4 TDIs (VE and PD) 13 December 16th, 2016 11:49
97 b4 went through puddle all of a sudden rough running and white paste in oil (PICS) bigblue VW MKIII-A3/B4 TDIs 15 November 22nd, 2010 10:39
Injector balance!!!! rough idle rowndhouse TDI 101 6 December 29th, 2007 18:39
'97 US Passat (B4) rough running for first 30 seconds hamilgs VW MKIV-A4 TDIs (VE and PD) 6 October 18th, 2002 11:03
Page generated in 0.20318 seconds with 11 queries
[Output: 136.33 Kb. compressed to 114.26 Kb. by saving 22.07 Kb. (16.19%)]
