Old December 23rd, 2017, 09:17   #1
Stromaluski
Stromaluski's Avatar
Default Upgraded SMIC for Jetta
Does anybody have any more information on what exactly doesn't fit about the pwrhaus mk3 intercooler? I found two threads that both say they aren't a direct replacement, but neither goes into detail (or at least doesn't anymore since the pictures no longer work).
http://forums.tdiclub.com/showthread.php?t=417608
http://forums.tdiclub.com/showthread.php?t=412539
-Andrew
Stromaluski is offline   Reply With Quote
Old December 23rd, 2017, 09:39   #2
Mongler98
Looks like mounting and duct works need some fab to fit. From what I gather about the other threads is that it’s not a 100% bolt on part and that there is probably not enough room in that spot for this unless you get creative. If you have the means to weld aluminum or some basic skills you can make this work. Check out Alumaloy. It’s a brazing rod that melts at 800*F. imagine welding with a soft almost melting crayon. It’s not too difficult to use and won’t melt out the aluminum your working with. I have made many parts using it. All you need is a Stainless Steel wire brush in the small and the medium size and that welding rod and a plumbers welding torch with a propane bottle, MAP gas is a bit too hot for this stuff but can work. Some use fluxes but I go for the one that does not.
IMO go with a front mount 27x7x2 or a smaller. I got the 27x7x2 to fit without cutting the rebar to death. Just had to do a bit of trimming on the lower lip and cutting the tabs on the AC condenser and welding them back on with the condenser much closer to the radiator. If you put electric fans on the radiator and modify the mounting on the radiator to push it back 1 inch and mod the AC b rackets and trim a bit off the lower lip on the rebar you can make it fit. You can check out my build. I’ll send you pictures if you want. I think it will be about the same amount of work to make this one fit vs a FMIC.
IMO upgrading the side intercooler is a small gain compared to a FMIC. If you want to go big and not go fmic go with a water to air side mount. Its more work and $$$ but saves room.
Water injection can be done for about $100-$150 and would be the most compact way to go for EGT control. Get an Auber EGT gauge and wire the relay into the pump system.
Hope this helps.
Old December 23rd, 2017, 09:44   #3
Mongler98
I got an ebay kit for the pipe and the FMIC but you need to clean the pipes out 100% as the mandrel bending leaves aluminum flakes behind.
Old December 23rd, 2017, 09:52   #4
Mongler98
http://forums.tdiclub.com/showthread.php?t=387812
Old December 23rd, 2017, 11:23   #5
Stromaluski
Originally Posted by Mongler98 View Post
Looks like mounting and duct works need some fab to fit. From what I gather about the other threads is that itís not a 100% bolt on part and that there is probably not enough room in that spot for this unless you get creative. If you have the means to weld aluminum or some basic skills you can make this work. Check out Alumaloy. Itís a brazing rod that melts at 800*F. imagine welding with a soft almost melting crayon. Itís not too difficult to use and wonít melt out the aluminum your working with. I have made many parts using it. All you need is a Stainless Steel wire brush in the small and the medium size and that welding rod and a plumbers welding torch with a propane bottle, MAP gas is a bit too hot for this stuff but can work. Some use fluxes but I go for the one that does not.
IMO go with a front mount 27x7x2 or a smaller. I got the 27x7x2 to fit without cutting the rebar to death. Just had to do a bit of trimming on the lower lip and cutting the tabs on the AC condenser and welding them back on with the condenser much closer to the radiator. If you put electric fans on the radiator and modify the mounting on the radiator to push it back 1 inch and mod the AC b rackets and trim a bit off the lower lip on the rebar you can make it fit. You can check out my build. Iíll send you pictures if you want. I think it will be about the same amount of work to make this one fit vs a FMIC.
Hope this helps.
Thanks for the advice, but thst's way more work than I'm looking to do.
-Andrew
Old December 23rd, 2017, 11:34   #6
Mongler98
well let us all know how you got it to fit because int he last 30 minutes i could not find one single post anywhere on the internet about this issue for this upgrade. Im sure someone has but isnt sharing. Just curios, why the upgrade? Uping the boost can do the same thing as this can for EGT's More boost and or water/Meth, or just water injection might be your go to for this.
Old December 23rd, 2017, 11:36   #7
Mongler98
and FYI, the work to make my FMIC was only about 6 hours of work.
Old December 23rd, 2017, 14:11   #8
Stromaluski
I was just looking at upgrading because I have to replace my intercooler anyway. One of the POs of my car left the headlight bulb out of the housing at one point and turned on the headlights. Melted the housing and a spot on the intercooler. I replaced the headlight shortly after buying the car, but the intercooler held pressure until just a few days ago. There's now a small hole in the middle of the melted spot. With what I've been reading, I have a feeling that I will simply end up getting another stock intercooler.
-Andrew
Old December 23rd, 2017, 14:25   #9
Steve Addy
TDI(s): 97 Mk3
I like the idea of fmic but so much work making sure that it's all properly fitted. If you do decide to go with factory replacement LMK, I think I have a spare Mk3 cooler I'd be willing to sell off.
I'd really like it if the pasenger cavity on the Mk3 wasn't filled with AC junk and horn stuff, I'd try installing another cooler over there ala 2.7T Audi cars.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old December 23rd, 2017, 14:36   #10
Mongler98
I also have a stock mk3 TDI intercooler in excellent shape, i ave all the parts i took off when i did my build. If you are interested it is also for sale.
Old December 23rd, 2017, 16:36   #11
ToddA1
Fuel Economy: Dismal
If it’s just a melted hole you’re dealing with, I’d prep it and pack some Quick Steel, on it. I’d bet it would work.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old December 23rd, 2017, 19:14   #12
Stromaluski
Steve
I agree on both statements. The older I get, the less I enjoy heavily modifying things, because inevitably there will be something that I didn't think of that will cause a failure of some sort. I also like the idea of the dual SMIC, and was tempted to pull a setup off of one of the 225hp TTs that I came across in a junkyard, but it was not even close to fitting on anything else from what I read.
Originally Posted by ToddA1 View Post
If itís just a melted hole youíre dealing with, Iíd prep it and pack some Quick Steel, on it. Iíd bet it would work.
-Todd
I've also been tempted to try that. Not really sure yet what I'm going to try. No point in ordering anything in the next couple days.
Judging by the pictures on ECS Tuning, it almost looks like the new OEM intercoolers have metal end tanks?
https://www.ecstuning.com/b-genuine-...er/1h0145805b/
-Andrew
Old December 23rd, 2017, 19:34   #13
ToddA1
I’d be more tempted to fix it for $5, lol. I never really looked at the Jetta IC... do one of the outlets unbolt?
-Todd
'97 B4: Stock
Rabbit build
Old December 23rd, 2017, 19:39   #14
Stromaluski
Iíd be more tempted to fix it for $5, lol. I never really looked at the Jetta IC... do one of the outlets unbolt?
-Todd
It does, and there is an oring between the intercooler and the outlet. I'll make sure to get a picture when I take mine apart.
-Andrew
Old December 23rd, 2017, 19:45   #15
ToddA1
Interesting.... as much as VW skimps to save money, the fact they add extra parts on the A3 is counter intuitive.
The interior power lock switch is another example. Btw, the A3 tilt column is a joke; it may as well be fixed position.
-Todd
'97 B4: Stock
Rabbit build
Upgraded SMIC, how much improvement? silverbox TDI Power Enhancements 53 June 20th, 2010 23:56
Upgraded SMIC G2 GofF TDI Power Enhancements 40 April 14th, 2007 16:01
Tyrolsport Upgraded SMIC dave333 Private TDI Items for Sale/Wanted 11 September 28th, 2006 19:40
Huge data of FMIC verse SMIC verse Upgraded SMIC 03_01_TDI TDI Power Enhancements 10 June 28th, 2005 12:15
upgraded SMIC robnitro TDI Power Enhancements 9 May 17th, 2005 20:31
Page generated in 0.17426 seconds with 11 queries
[Output: 130.25 Kb. compressed to 109.00 Kb. by saving 21.25 Kb. (16.31%)]
