Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old March 21st, 2013, 21:41   #1
chzweeth
Fuel Economy: 41
Default Mileage drops from 44 to 34 mpg
A few weeks ago I managed to get 44 mpg with a cetane additive on a highway road trip on a cold, windy day. Speeds ranged from 35 mph in the snow drifts to 70 mph on the open freeway (2003 VW GLS wagon, automatic).
Since then a loose tie rod was replaced and the front end straightened so the drift to the right was corrected. I also had the two tires with the slow leaks seated and sealed properly.
I was expecting a slight improvement with these changes, but on this last road trip, the mileage dropped to 34 mpg. It was another windy day with some snow drifts and icy patches, but nothing as bad as the prior trip. The return trip over the same route on a wide open road yielded a little better 36 mpg.
Fuel, terrain, driving behavior, load, etc. were essentially the same coming and going.
The first few road trips I was getting 39-41 without the additive.
There isn't a fuel leak, so what could cause such a dramatic change?
My family has had VWs for the most part since 1957, starting with bugs and buses, then squarebacks and now TDIs. The '65 bus with the 50hp engine is still my favorite!
chzweeth is offline   Reply With Quote
Old March 22nd, 2013, 02:06   #2
MikeMars
You say it was windy ... if you had a tailwind on the first trip, and a headwind on the second, then there would be a big difference in MPG between them.
I would check wheel alignment/tracking/toe given the recent history.
Audi A2 TDi 1.4*, 6M/0.588, mild aero mods, 103hp remap (* 3 pot version of 1.9PD)
Y2000 Passat TDi 115 PD RETIRED, M5, Best 75MPGuk, usually 60-70. 900m clubx7. 1000 mile clubx3.
VW Fuel saving tips
MikeMars is offline   Reply With Quote
Old March 22nd, 2013, 03:34   #3
jet_a
jet_a's Avatar
Fuel Economy: See fuelly below
I suppose in Wisconsin the winter additive is standard everywhere, but did you fill up anywhere South? Did you fill up at the same location? Just wondering if the winter additive formula was the same each time.
2012 Sportwagen DSG with sunroof. Build date: 06/12
jet_a is offline   Reply With Quote
Old March 22nd, 2013, 05:06   #4
fruitcakesa
Fuel Economy: 40's
My wife's 02 Wagon auto has had the same mileage drop this winter.
I aired the tires up to 40 psi and the next tank was 38 mpg. She will be filling again soon so I will have more data.
I think a combination of cold, blustery weather, short local drives and winter fuel are the biggest culprits along with lower tire pressure
2004 Jetta TDI wagon 5 speed 278k+ VNT 17 Kerma tune. new heater core
fruitcakesa is offline   Reply With Quote
Old March 22nd, 2013, 05:19   #5
detroitmike
detroitmike's Avatar
i hate these types of threads.
Power Service Diesel Fuel Supplement every tank
detroitmike is offline   Reply With Quote
Old March 22nd, 2013, 07:46   #6
MikeMars
Yeah, it's definately a FAQ. Somebody should write a sticky covering this stuff ...
VW Fuel saving tips
Old March 22nd, 2013, 08:30   #7
chzweeth
Fuel Economy: 41
The fuel is exactly the same as is the additive.
Wind was predominantly from one side or the other - not a head or tail wind.
I may be a newbie on this forum, but I'm certainly not a newbie to driving. I've combed through the FAQs and there is nothing specific to a significant drop in MPG when the conditions are essentially the same.
If the answer is so simple, why not point to it rather than a holier than thou non-answer?
Old March 22nd, 2013, 08:47   #8
MikeMars
Nobody said it was simple (that's what makes it difficult to answer). But the simple fact is that we don't have a sticky/informational post on here which at least says the basics.
So what exactly is the problem with us pointing that out? Why get defensive?
VW Fuel saving tips
Old March 22nd, 2013, 09:34   #9
jettawreck
jettawreck's Avatar
It's not always so simple. All the above is good advise.
Crosswinds are almost as bad as headwinds, it seems.
Try it w/o additive. Really, I do better w/o additive and I pay a lot of attention to the mileage and mine has been very good this winter. It's still been below 0F most morings and this will be another 800+ mile tank. 52ish mpg again. Commuting 40 miles one way.
Make sure the autofail 01M tranny is actually going into 4th gear and the torque converter is locking up properly. (any CEL/codes?)
Short drives in cold weather kill mileage, how long were the trips?
Verify that the coolant temp is actually getting up to normal. The dash gauge is no real indicator, it will read 190 when the coolant is anything above 165, which is far from ideal.
2004 Cadillac SLS (wife's)
jettawreck is online now   Reply With Quote
Old March 22nd, 2013, 14:48   #10
chzweeth
Fuel Economy: 41
Thanks for the response.
The 44 mpg trip was 505 miles with 1/3 off cruise on two lane, twisty-turny roads along the river and ridges @ 55 mph or less, 1/3 on divided 4 lane on cruise @ 70 mph, and 1/3 off cruise with snow drifts @ 35-45 mph.
The 34 and 36 mpg runs were 275 and 319 miles respectively on the same 4 lane freeway. The outbound was mostly on cruise @ 70 mph with some lowering due to the drifts and ice; the return was about 40 miles in town and then on cruise @ 70 mph on clear roads.
It was actually windier on the 44 mpg run and more into the wind, with far more changes in speed due to the roads and terrain.
If I had seen a modest change in mpg, I might chalk it up to the conditions; but when the conditions are worse and the mpg is better, that has me puzzled.
I started using the additive because the prior owner used his own homemade bio-diesel and the car also sat for a year. Yes the fuel filter was changed and it wasn't too bad.
The timing belt, water pump, turbo and fuel injectors were also recently replaced by the previous owner.
I also checked the cetane of the fuel available in my area and found the winter blends were in the 40 to 42 range. In all the years I've driven diesels, I have only used the dirt cheap truck stop diesel when there was no other alternative.
The car also had some hard starts when it was parked overnight in the cold we've been recently experiencing. I changed the oil from the 10w/30 to the 5w/40 and that has helped.
Prior to the 44 mpg run, I was getting 39-41 mpg on the highway without the additive and the repair to the tie rod and tires.
My thoughts are I have an injector that isn't working properly or a minor fuel leak (the pavement is dry and I had them look for leaks when it was last in for service).
Old March 22nd, 2013, 15:03   #11
jettawreck
jettawreck's Avatar
Homebrew bio could well have damaged the injectors/nozzles and would explain some of the low fuel mileage you are getting. Poor spray patterns can make for big issues over time.
Look into the tranny shifting properly and TCC working as it should.
How are you filling the tank?? Search "ventecomy" and how it will make your fuel fill ups more accurate. A couple qts more/less per fill, especially on a partial tank, will make for widely varying mpg results.
Injection timing. Depending on where its set (TB was done by owner using homebrew bio, so I question it) can result in poorer cold starts and less than optimal performance/mileage.
So there are lots more possibilities and not always so easy to answer a question point blank.
Old March 22nd, 2013, 15:54   #12
fruitcakesa
Fuel Economy: 40's
JW: These are key and often overlooked issues as far as mpg's go.
My trans TC did not lockup in 4th for the 1st 76k miles I owned the car and I was clueless about it. Never saw better than 35-37 mpgs.
One day it started locking up and mpgs rose to 40-42.
Since then it has varied from 34-46.
My wife never waits for the foam to settle so her mileage runs are always more than they actual would be if she brimmed it.
It does not take much to radically change your numbers.
Old March 22nd, 2013, 17:39   #13
chzweeth
Fuel Economy: 41
Yes, I'm very much aware of the issues with foaming when fueling up. This may be my first VW TDI, but it isn't my first diesel.
The car now has 160k, so we're well past breaking anything in.
The turbocharger, timing belt, water pump, etc. as well as the nozzles were replaced about 30k miles ago.
As I drive I keep an eye on the rpms. I've been pleasantly surprised at how low 2,600 they are at freeway speeds, even up steep grades.
Old March 22nd, 2013, 19:28   #14
colorado_matt
MAF, fuel temp sensor, etc.?
colorado_matt is offline   Reply With Quote
Old March 23rd, 2013, 06:38   #15
jettawreck
jettawreck's Avatar
Just because you are aware of the diesel foaming issue, does that mean you fill to the same level each time or just let it settle down and let the pump shut off? There is a lot of variance in the VW fuel tank due to the expansion tank that is in the system. They use the same tank system for the gasser models.
I don't know what rpm the auto runs at "freeway speeds" (whatever that is maybe anywhere in the 65-85mph range), so that is useless info. Maybe post an rpm at a specific speed, such as my 5 speed runs about 2100 at 60 mph.
Haven't answered the injection timing question(s). Some of your issue point directly to retarded timing, in my opinion. TB and other parts were replaced be previous owner. That may/may not be a good thing. Just because he perhaps seemed to know VW TDIs enough to work on them doesn't mean he really did things correctly. Many, many of these engines have been brought to an early death by TB changes that were done incorrectly.
I have no fondness for the 01M automatics, but you should be getting better numbers than you appear to be.
You've been given some good things to check out by Mike and others, as well as plenty of things to search out in the FAQs/stickys, but instead seem to be looking for a easy cure.
Best of luck getting it figured out. JasonTdi is in Madison, WI and is a very respected TDI guru. If you don't have VCDS and can post some logs (coolant temp/timing graph/etc/etc), I would suggest taking the car to one of the forum gurus.
My pair of 2009 TDI Jetta MPG thus far. 44.6 MPG. Rod Bearing TDI Fuel Economy 1 December 16th, 2009 21:36
Bear Wagen break-in mileage: 44 mpg; I am impressed !!! jeepescu TDI Fuel Economy 4 October 2nd, 2006 23:47
44.44 mpg.......around town DRbillZ VW MKIV-A4 TDIs (VE and PD) 2 May 15th, 2006 10:12
Why mileage so low for '03 TDI? (44.2 MPG hwy) belfert TDI Fuel Economy 25 July 2nd, 2005 14:47
New Beetle - bad mileage! 34 mpg??!?!? Edster TDI Fuel Economy 3 January 2nd, 2004 03:23
Page generated in 0.18212 seconds with 11 queries
[Output: 138.93 Kb. compressed to 116.88 Kb. by saving 22.05 Kb. (15.87%)]
