Brent_B
they have some 205's for 80.00 has anyone ever tried them?
TDI'ed said:btw careful about the reputable vendor comment...
thanks I am interested in hearing how it goesTDI'ed said:I'm dynoing my car this weekend.. I'll be sure to let you know... btw careful about the reputable vendor comment...
I bought a set a couple of years ago from the guy on eBay just to see what they were like. First thing I can say is they may say that they are made in Germany or France, but their just cheap Chinese knock offs. I installed them in a car to see how they would perform, they lasted about a week before I began getting excess smoke and terrible fuel mileage. They don't last.Brent_B said:I just really would like to hear from the people that have tried them, if you have never had any personal experience with them I am not really interested in hearing your opinion. thanks
Brent
do you have proof? Do you have experience with them? As long as an injector is tested prior to running then it shouldn't be a problem. Since I work in the motorsport industry I would have the spray pattern checked prior to installing them. Like I said at the begining I am looking for real world results not scare tactics or he said she said info/dis-info Thanks Brentbikeprof said:OUCH!
What most of us do not know is that the PISTONS will also reflect the quality of the nozzles!
In time, the pistons will be damaged by the less quality spray pattern !
Something like FYI!
A friend of mine is being an idiot - not only has he used ebay nozzles, but he used ebay nozzles for a VAG, despite my attempts to tell him the pattern was wrong - 150 degrees instead of the rover's 145, he went ahead anyway.Brent_B said:do you have proof? Do you have experience with them? As long as an injector is tested prior to running then it shouldn't be a problem. Since I work in the motorsport industry I would have the spray pattern checked prior to installing them. Like I said at the begining I am looking for real world results not scare tactics or he said she said info/dis-info Thanks Brent
What??? You can´t compare a compression ignition engine with a spark ignition engine (diesel vs gasser), completely different design.Sip'n Diesel said:IMHO, Bosio or Bosch are the only manufacturers whose nozzles belong in a TDI. are you aware that the minimum pop-pressures are 200 bar? that's almost 3,000 PSI... at a minimum. AFAIK, that puts these particular breed of nozzles in a whole different ball-game than just about any other nozzles
have you seen any pressures that high on other platforms in the motorsport industry? one of my co-workers has a project car (which he rarely drives) which is a Nissan 300z (IIRC) Twin Turbo... I told him my TDI has a high pressure injection pump, and that the nozzles pop around ~3,000 PSI... he did not believe me. further, he claimed that it was actually impossible and that my fuel lines should be exploding if that were true. apparently he missed the part about the high compression ratios, and the direct injection into the cylinder. I asked him what kind of pressures the Nissan sees: he said ~600 PSI...
OBVIOUSLY it's not comparing apples to apples! thanks for pointing that out SHERLOCK! I just thought maybe the OP would appreciate my attempt to save his TDI from EPIC MOFO FAILnokivasara said:What??? You can´t compare a compression ignition engine with a spark ignition engine (diesel vs gasser), completely different design.
Even a VW 1.6D from -82 has over 200Bar peak in the hard lines (the pop pressure is 135)
You don´t have a high pressure pump, a common rail diesel has a high pressure pump, at 30000 (2000bar) PSI.
THE OP would have appreciated if you would have followed what I asked forSip'n Diesel said:fine! go ahead, put the POS e-bay nozzles in the car! I just DGAF! I hope the car blows up!
