Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old February 8th, 2018, 15:42   #1
ss04vv
Fuel Economy: 5.2L/100km
Default Whats it worth/feeler thread 03 Jetta Wagon, 260k, $4000 in new parts
If interested, text 905 379 8089 for pictures and/or more information
I'm in the middle of piecing back together my 03 Jetta Wagon after a lifter took out my cam and a valve (no piston to valve contact, just did some damage to the top of the lifter stem). Tons of new parts. Never planned to sell this car but just picked up a Unicorn of a TDI, 5 spd Land Rover Discovery from Spain so contemplating selling the JSW. Below are a list of information and parts I'm in the middle of replacing. Expect to have the car done in a week or two. I've been working on these cars for 10+ years, and building cars in general for another 5+ on top of that and always do everything OEM++ and by the book.
Details: ~260k, Silver, Wagon, Black leather w/sunroof, 2nd owner (for 4ish years), no accidents, very small amount of rust at fender and rear hatch (original owner spent all winters in florida - retired ex-plane mechanic so he was almost as anal with the car as I am), all service history/parts receipts since new.
List of brand new parts alone totalling just under $4000 (like I said, I never planned to sell this car) Engine parts from IDparts.com and suspension from Rockauto - All receipts available and photos of work in progress as well. Also has a set of 70% Bridgestone Blizzak winter tires on OEM alloy Rims. Will likely need new summer tires on the 2nd set of OEM Alloy rims.
ENGINE
- rebuilt head (everything new)
- Cylinder Head Install Kit (A4 ALH)
- Head Bolts: OEM
- Head Gasket: 1 Hole
- High Mileage Timing Belt Kit (ALH)
- Camshaft Sprocket: OEM
- Oil Cooler Gaskets: Yes
- Serpentine Belt: Gates "Green Stripe"
- Hard Coolant Pipe o-ring:
- Serpentine Belt Tensioner Style: Shock Only
- Coolant: None Needed
- Timing Belt: Continental
Upgraded Complete Injectors w/ Bosio Nozzles
- Core Charge:
- Prepaid Return Label:
- Nozzle Option: Bosio PP 520
- Model Year: 2003- Intercooler Bracket (ALH Jetta Golf)
- Malone Stage 1.5 Tune (not purchased or installed yet, but intended to be purchased and installed at discretion of new owner)
- 3 x Complete Filter Pack (ALH)(BEW) (all included)
- Air Filter: Mann w/Prefilter
- Cabin Filter: Charcoal
- Fuel Filter: MANN-FILTER
- Add 2nd Oil Filter:
- Cam Follower/Lifter Set (A4 ALH)
- Vane Actuator VNT-15/VNT-17 (A4 ALH)
- Actuator Circlip
- Oil Filter Flange Gasket (A4 ALH BEW)
- Oil Pan Gasket (A4)
- Oil Pump Pickup Tube O-Ring Seal (VW)
- Turbo Oil Feed Line Banjo Washers (A3)(B4)(A4)(B5.5)
- Diesel Fuel Hose 3mm (Return Line) - 1 Meter
- 5-Speed Short Shifter
Suspension/MISC
- MONROE 21715255613 Suspension Kit (2 new Quickstruts, and 2 new shocks)
- Complete Suspension Bolt Set - Struts and Shocks (A4)
- 2 x Rear Shock Mount (A4) $31.90
- Rear Towing Springs PAIR (A4 Jetta Wagon)
- CURT 11083 Trailer Hitch & wiring
- Armrest Hinge Repair Kit (A4)
- Vented Fender Liner [OEM] (A4)
- POWER STOP ESK840 4 corner Rotor & Brake Pad Kit
ss04vv is offline   Reply With Quote
Old February 9th, 2018, 04:59   #2
breakfasteatre
I just recently purchased a wagon, an 06 mind you, but if it was me, I wouldn't pay any more than 4 grand safetied and certified.
Youve had the car for 4 years so I can only assume its paid off. If you get the money back in the parts i would call that a win.
if you post it for sale, dont say that you already picked up another car
breakfasteatre is offline   Reply With Quote
Old February 9th, 2018, 06:06   #3
2.2TDI
TDI(s): .
4k seems reasonable for a 15 year old unicorn wagon... You have to remember, majority of buyers won't care about the work you did to the car and money you spent..most will just see a 15 year old diesel wagon with 260km
2.2TDI is offline   Reply With Quote
Old February 9th, 2018, 11:10   #4
imo000
imo000's Avatar
Fuel Economy: Good enough
Unfortunately that's now buyers see this.
If I were the seller, I would hold on to the Jetta at least 6 months after the Disco is on the road. Those Land Rovers are notoriously unreliable.
imo000 is offline   Reply With Quote
Old February 9th, 2018, 14:15   #5
ss04vv
Listed it on kijiji last night. Waiting on a unicorn buyer for this unicorn car it seems. These alh jettas have their own little gremlins as we all know and they've all been handled and then some on this car. Unless I get what I'm asking for it, I'll likely keep it and just sell the disco if it comes to it.
https://www.kijiji.ca/v-cars-trucks/...ationFlag=true
Old February 9th, 2018, 15:34   #6
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
You might as well keep it for when the Rover is broken waiting on parts
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old February 9th, 2018, 17:38   #7
2.2TDI
TDI(s): .
7k? maybe if it was 4motion, and even then a big maybe... glws but like the other two said, you might aswell keep it at that price
Old February 10th, 2018, 06:42   #8
maxmoo
$7,000 for a 15yr old car that has the engine disassemled due to issues?
BTW...you forgot to list the newer air added to the tires.
maxmoo is offline   Reply With Quote
Old February 10th, 2018, 07:54   #9
ss04vv
Price reflects the car being assembled, not as is. And you're right. Ad edited to include new air.
Old February 13th, 2018, 12:45   #10
imo000
imo000's Avatar
How can you realistically expect a buyer to buy this car before it's put back together if they can't even take it for a test drive?
I would recommend first putting the car back together, then drive it for a weeks or so to make sure all the bugs are worked out of it AND THEN listed for sale with an add that's not two pages long. Also, posting pictures when the car is not on a dolly can help greatly increase the chances of landing and interested buyer. $7K is a very optimistic asking price.
Old February 14th, 2018, 17:01   #11
Uberhare
Uberhare's Avatar
TDI(s): Too many.
This. Since you asked in your original post, I will give my opinion. With the rust I see, it's a $3000 car when it's all back together.
Old February 14th, 2018, 18:29   #12
2.2TDI
TDI(s): .
Guess I was being generous when I said 4000 seems reasonable
Old February 18th, 2018, 15:12   #13
ss04vv
Tough crowd
Old May 18th, 2018, 18:48   #14
ss04vv
Car is now posted for sale.
Old May 19th, 2018, 09:41   #15
P2B
P2B's Avatar
Posted at roughly twice what it's worth, IMHO.
GLWS
Jettas for 35 years, TDIs for 16.
2003 Silver Jetta TDI GLS 300K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 230K PP520 RC2
2000 Canyon Red Jetta TDI GLS 560K
P2B is offline   Reply With Quote
Feeler.whats it worth.. 04 Wagon tdi campbellflage TDI Cars for Sale/Wanted 11 July 11th, 2013 17:28
03 Jetta automatic wagon, what is it worth unfixed, what's it worth fixed? marshalldanielp TDI 101 4 September 9th, 2012 09:26
Whats it worth. Mint 03 Jetta Wagon TDI w/ 185k and a 6 spd swap? ss04vv Ontario 19 January 24th, 2012 07:09
Whats it worth - 03 tdi wagon alkidd Ontario 27 June 9th, 2010 19:09
Whats it worth 03 wagon prt 2 alkidd Ontario 22 June 8th, 2010 08:35
Page generated in 0.16999 seconds with 13 queries
[Output: 128.41 Kb. compressed to 107.58 Kb. by saving 20.84 Kb. (16.23%)]
