Before I take action (and it seems to me that I need to !), may I just confirm that my turbo is ill.
I have an Audi A4, AFN Engine, 110bhp. 96000 miles done. Since I have owned it, from 55000 miles, I have had intermittent loss of turbo (limp mode), usually when doing 60mph + and accelarating. I seemed to fix the problem a couple of times by cleaning the MAP sensor inside the ECU, as it was getting clogged up with oil from the air inlet hose (causing fault code 00575).
Just recently, I have had almost constant problems with getting above about 60mph in 5th. I stripped the ECU again, this time I found a small quantity of oil had actually leaked onto the PCB ! I gave it a good cleanup, washed out the MAP sensor and hoses with IPA, and took the car for a spin. No improvement. Did a bit of internet "homework", and reminded myself of possible issues with my car. I thought I may be having N75 valve or MAF sensor problems, but after checking the travel on my VNT actuator, I think I may have spotted the problem. With a pair of thin pliers, I am trying to move the actuator arm, and it only travels about 5 - 10 mm. It sounds a bit rough when I do move it. I have taken the hose off the N75 have and applied vacuum with my mouth. Again, the arm moves, but not very far. How far should it move, and is the return spring supposed to be quite strong ? Seems like my turbo needs to be stripped and cleaned, although I am wondering if it could be the actuator itself.
I do give my car "some stick" (4500 rpm+) fairly regularly, as I know that these engines don`t like to crawl around for too long, so I am a little suprised that I have this problem. Having said that, a fair bit of my driving is around town, and at fairly low revs. Any advice/reasurance would be welcome.
