Hey
So the Jetta sometimes wouldn't start but then I would let it sit for a hour then it would . Eventually it got worse and now won't start at all.
I brought it to the shop and got it hooked up to every scanner they could try and it cannot be read. So the shop is assuming that the ecu is dead!
Now I'm trying to source a 99.5 Jetta ecu and I'm trying to figure out the correct part number .
Does anyone know the part number I need ?
Does it have to be a 99.5?
Will other years ecu work on it?
Thanks in advance for all your time ?
