04 BEW 5 speed car..
270k miles.. Previous Owner said all maintenance done by dealer before I owned it.
270k timing belt and cam / lifter swap done. Washed engine prior to beginning this project and caused a cam sensor code.. cleared and didn't return. Now that the new parts are on and it runs again the cam code is here to stay.. new sensor coming.
This has caused me not to be able to adjust my torsion value.. so keep that in mind
Now on to the next thing.. Friend and I debated and eventually agreed that since the old cam was worn so badly perhaps we should adjust the injector plungers.. see how off they might be..
#3 ran in almost a turn and a half.. while the other injectors only ran in a half turn.
Idle injection deviation is now -1.xx on one cylinder and +1.4x on cylinder 3
Is this something that will come back into itself.. is the fuel quantity something that the engine can "trim" over time or is it determined mechanically
Cam is a stock replacement from IDParts.. Not a colt..
