I'm working on replacing the timing belt on a new to me ALH TDI, and I'm seeing things that have me worried. The first uh-oh feeling came when I saw the marks from a previous mark and pray belt job. With the crank properly aligned by flywheel marks, the IP lock pin fits. The cam is just ever so slightly off. The cam lock plate will fit halfway in.
Fair warning: My pictures are HUGE.
Is this cam far enough off to create piston/valve interference, or is this small degree not enough to cause mechanical issues?
I'm also concerned about wear on the camshaft lobes. I'm fairly certain this car has not seen proper oil change intervals, and possibly not even the correct oil for all I know. I'm guessing this cam is toast?
Thanks for any advice you can give.
