Digital Corpus
I know nothing beats a dedicated, purpose-built sensor for any specific application. However, in tuning of of VNT/VGT turbochargers, I'm slightly surprised to not see any audio engineers here on the forums. We have all sorts of other engineers present. Anyhow, I digress. It dawned on me last night to open up a spectrogram app while I was coming home from work and look at my engine and turbo sound. Since I have an open exhaust, I have a whistle from the turbo that is readily available and I figured the FFT would pick it up; well, it did:
Click to embiggen:
Note: That's the weakest sample I had, but the only one I paused the recording to take a screen shot.
That's a shift from 2nd to 3rd gear with a peak frequency about 13.5 kHz. With 9 blades on the turbine and converting from times-per-second to RPM, this gives a wheel speed of 90K RPM. For the GTB1756 specifically, if the 'ole 2056 map is close enough with a rated speed of 190K RPM, this puts the aural frequency at 28.5 kHz. Yes, that is outside of the human hearing range, but a standard 96 kHz, 24-bit pickup would capture that as long as the mic isn't low-passed to filter out ultrasonic frequencies.
Usually weird side-application stuff like this will pull a few hits on Google, but I have nearly nothing on this specific application. For my own curiosity, I thought I'd share. Probably going to use a mic with specs stated above to capture some other samples and see what Audacity will spit out. Granted, this isn't a real time application with a turbo speed sensor, but the temporal resolution is hard to beat.
Click to embiggen:
