larrydc
Bent rims on my 96 tdi Passat. Is there any used ones anyone knows of I can purchase?
Call a scrap yard near you. They usually sell used parts.Typed in VW 4x100 wheels/rims on Craigs and didn't get anything.
Put a "wanted to buy" ad in the classifieds here. Also check over on Vortex classifieds and Passat World.The problem I have been having with the scrap yards around here and not to far away is that they scrap them out first thing because they are number 1 scrap prices.
The other problem is it seems the only exact fit has to come off of a passat tdi 95-97. That's really hard to find.
via car-part.com only place to have one in CA isI posted a want but have received no responses yet.
You are referring to the Hub center boar. On A3 they are 57.1mm. Simple hub center ring will keep everything in line.I don't know about that... VW discs and drums have a raised section that fits perfectly in the centerbore of VW wheels. I'm sure the ball seat helps, but I'm thinking the raised portion is there for a reason.
-Todd
Todd is correct, VW uses (needs) hub centric wheels so if the center bore is too large a person will need to measure and buy spigot rings.I don't know about that... VW discs and drums have a raised section that fits perfectly in the centerbore of VW wheels. I'm sure the ball seat helps, but I'm thinking the raised portion is there for a reason.
-Todd
