psst1997
- Joined
- Aug 14, 2006
- Location
- Kentucky
- TDI
- 90 Corrado G60, 90 Corrado 3.6, 92 Corrado VR6, 97 Passat TDI, 2005 Jetta TDI, 2006 Touareg V10, 2011 Golf TDI
This is a GLX model with heated leather seats, and wood grain trim. I bought this car in 2012 to replace my daily driver B4. At the time it had a failed Automatic transmission. I replaced it with a good working auto from there and since then have replaced that transmission with a 6 speed imported from the UK. Car had a timing belt failure and the head and Balance shaft were replaced by the previous owner. I have a mk6 Golf now and I just don't drive this car and would like to pass it on for someone else to enjoy. It is a great car to drive, smooth, big, comfy. The manual trans definitely breathed new life into the car. Currently just under 219,000 miles. In town mpg can range from 32-35. Highway is 40-45 depending on speed of course. I tend to have a heavy foot.
Update
-Tune updated and CEL is now gone 2/16/17
-Trunk latch replaced 3/5/17
-Front bumper painted and replaced 3/8/17
Current Maintenance
-Geared Balance Shaft @174k
-AMC Head @174k
-Timing Belt/WP/rollers/seals @204k due to leaky cam seal. Next belt due @284
-Meyle Control Arms @204k
-Rear Main seal @204k
-Motor Mounts @204k
-OEM Transmission mounts @215k
-Valeo 228mm Single Mass Clutch/Flywheel upgraded disc and pressure plate by South Bend Clutch @215k
-Coolant Flange @215k
-New OEM Battery @216k
-New windshield @218k
Modifications
-6 speed 01e swap GAZ code
Final drive 31 : 8 = 3.875
1st gear 28 : 8 = 3.500
2nd gear 34 : 18 = 1.889
3rd gear 32 : 26 = 1.231
4th gear 27 : 31 = 0.871
5th gear 26 : 39 = 0.667
6th gear 23 : 41 = 0.561
-Gear and Speed @2k RPM
1 2 3 4 5 6
11.0 20.3 31.2 44.0 57.5 68.4
-2350 RPM @80 in 6th
-Fully wired for manual swap including reverse lights and cruise control. No starter interlock.
-W8 Power Passat Front seats
-Morimoto 35w 6,000k HID Upgrade
-STG2 TD Tuning Tune
-EGR/Cooler delete
-Monster Mats
-Bridgestone 195/65/15 tires 70% tread
Issues
-CEL for Maf - P0101 Code This car has had this code since I bought it and was a known issue from the previous owner. Has new OEM maf and drive-ability is not affected. Fixed - 2/16/17
-Couple surface rust spots from chips but will be touched up.
-Front bumper needs a repaint as it was in a minor collision by the previous owner. I have a spare that will be painted and replaced soon. Fixed - 3/8/17
-Trunk latch doesnt catch 25% of the time. Fixed - 3/5/17
-Homelink visor broken. Have a replacement that needs installed.
Pictures
Here is a link of current pictures of the car. It was cold and snowing when i took these so forgive the quality. I plan to address some of the issues and will update pics as I do.
http://s225.photobucket.com/user/psst1997/library/04 Passat
Receipts
https://drive.google.com/drive/folders/0B7HRcMsfbFxMR1JZRC14TTY2Rzg?usp=sharing
Price - $7,200obo
Update
Current Maintenance
-AMC Head @174k
-Motor Mounts @204k
Modifications
1 2 3 4 5 6
-EGR/Cooler delete
-Monster Mats
Issues
Pictures
Receipts
Price - $7,200obo
