Ski in NC
You must be careful when rolling an engine over by hand checking for interference between valves and pistons. When sitting, hydraulic cam followers bleed down to a lower dimension than when running. Roll over by hand, seems ok. Start up and cam followers pump up and then contact may occur. I'm not suggesting this is the problem, just a note to those changing cams.
One trick I've used is to set the engine at TDC, then rotate cam by hand (pulley on, belt off, cam lock out) and see how far I can rotate in each direction before I feel valve to piston contact. Gives you an idea of how much room it actually there. Of course if followers have bled down, this changes things.
-Eric
-Eric
