bhodgkiss
Previously I've had R520's maxed out at around 190bhp with 10mm pump and BV43 at 1.7bar
Today the HFLOX 0.341s went in
All running 'ok' with a best guess remap to aim for the same power
- idle IQ at 5.5mg (no smoke when warm, a bit of white when cold) and didn't need to adjust.
- I haven't checked static timing yet, when driving it follows requested timing ok but won't go more retarded than 0deg at the mo.
- a white haze (very light) when accelerating hard
- not much response under 1600rpm (map needs some work)
- EGTs at 830C max so far so similar to R520, probably hotter.
- boost creeping slightly to 1.8bar as before
So all in all running 'ok'. I do have an 11mm pump which will go on when I do my cambelt this summer. GTB2060VKLR too, currently teasing me in the garage
Oh and the forged bottom end which is sat in a box.... The list goes on...
Will update with mapping improvements and mpg etc
Ultimately, probably worse than the R520s for ~200crank hp with a 10mm pump at the mo.
Oh aside, I went to fit the injectors and can't get onto the new injector 'retainer clamp' bolts with a socket! The new bodies are different to mine, with a T30 torx c'sunk bolt sticking out where the fuel return pipes plug in, which mask the clamp bolt! So had to nip up with a stubby 13mm spanner....as per image I found below.
http://www.dbwllc.net/app/uploads/2014/09/injectors02a.jpg
Have I got the wrong bodies? Do I need different bolts? I didn't know some were like this. My originals are simpler in design and don't mask the clamp bolt.
