caddybruva
What's up, I got a 1z m-tdi. I was curious to see if I could run a lift pump. So I sent a email to Hans auto parts cause that's where the mechanical pump came from, asking more specifics about the pump and if I could run a upgraded fuel pump because in the ad of this pump it says they basically copied the euro design of the 2.8tdi. That's all... After a slow response the answer I got was, that I have a 17mm shaft and a 11 mm head.. and to not run a inline pump because the injection pumps are not designed for one. Sooooo what's the story.. can I run a lift pump with the mechanical pump? If not why not?
