Hello Guys,
i know this have been like discussed thousands of times, but still i need help
extracting IMMO codes from clusters is not an issue, i've vag-com and vag-tacho and couple of other interfaces.
so for the main dilemma,
i own a B5, year 2000 with auto tranny.
i got my hands on a new cluster with the half screen "half fis", so i removed the old cluster, and fit in the new cluster.
before fitting the new cluster i'm ABLE to access the cluster and ECU using vag-com as usual, but with the new cluster fitted, i'm UNABLE to access neither the cluster or the ECU using vag-com or else.
the car comes with this cluster.
https://imgur.com/a/pWqBv
which is dull and old, without any screen, only the PRND321 indicator for the trans.
the new one is this one
https://imgur.com/a/cPGzR
i don't know why i'm unable to access it or the ECU, some car electricians said that this is wiring issue, and if i could rewire the green/blue connectors wires i would be able to make it work, some said this CLUSTER isn't compatible and i hope they are wrong, it gave the car a new soul.
Help appreciated
Help appreciated
