brianteel
it is the only thing left that could be wrong.
the VNT actuator... go ahead and change the vacuum lines if you havnt already... its cheap to do...That whooshing sound the turbo makes wen u shift well my jetta did it then just one day it stopped and seemed to loose a lil power wat would cause that to stop that noise and power loss
I got it moving nicely. It seems once it warms the boost is a little erratic. It will run 25 psi then drops to 15 psi
Sent from my Galaxy Nexus using Tapatalk 2
If the actuator was stuck that means there is likely rust inside and it will stick again. Check out the video I made of a sticky actuator and a new actuator side by side: http://www.youtube.com/watch?v=hGWxQkEWA-g
Are you talking about PB Blaster on the arm of the actuator? OR also in the internal parts of the actuator? I did the OC method on turbo, and my actuator was frozen, removed and broke it free, got lost of fine rust out of the tiny hole on the side, but I didn't want to put anything INSIDE the actuator for fear of ruining the diaphram. Put everything back and I'm still getting low power at low rpm, then a boost of power at about 2800-3000 rpms. Low power then is ok until I turn off car, then happens again. I haven't had the chance yet to get car jacked up again to test actuator with MityVac. I guess if actuator is stuck again, cleaning it internally by spraying something inside wouldn't hurt, cause if it's stuck I have to buy a new one anyway. (By the way, it DOES hold vacuum)Well, that could be a couple of things. You could have coked up VNT vanes that you broke free; if that is the case, it will likely happen again, sooner or later. The solution there would be a cleaning (Mr. Muscle or Easy-Off oven cleans with NaOH, or sodium-based lye). The other issue would be within the actuator. I use PB blaster on my actuator to try and free up the components. You may want to give it a soak and try again. Or, it could be both.
If you have bad innards in the actuator, you may need to replace it ($99 at ID parts).
I would hesitate to do this because anything that gets into the actuator ultimatelyOK thanks.
The thing I'm really needing info about is can I spray something (and what so as not to degrade any internal parts) INTO the actuator to clean it in case it's sticking again.
2x on the above, do not use spray cleaners in the actuator.OK thanks.
